I will see what i can do about that, i will add to TODO list
I will add this to my todo list also
bachoo786 would you mind installing this apk and let me know if duckdns works with it?
http://surodev.com/ariela/app-release.apk
inutilis the same apk will allow user continue setup without allowing location permission.
General question: was the Firebase functionality tried by anyone? Can you let me know how it works?
Thank you,
Ionut
hey @lonut I just tried it and it tells me server connection failed…connection to home assistant server failed Please check the URL / IP provided and try again.
So its not working.
Great! Location permission granting can now be skipped.
Since I am not home currently the only option to see something further would be to connect using my duckdns domain, but as @bachoo786 wrote it is not working yet.
One more thing I noticed - app should check if there is internet connection at all before attempting to scan network.
Please download the apk from http://surodev.com/ariela/app-release.apk and please try again now
[quote]
One more thing I noticed - app should check if there is internet connection at all before attempting to scan network. [/quote]
I will see what i can do about this.
“Contains ads”
I would rather pay few quids to have an app which respects my privacy.
A PRO version will be available for you in a few hours.
bachoo786 can you tell me if latest apk works with duckdns?
Ionut
as soon as i choose 1 of the groups (devices, lights, etc) it shows the chosen entities and right after that it flips back to the menu where i have to choose what to see.
and why is sensors missing?
and do you still think about my issues from before?
Will HAnotify be included in the app or will I always have to install an apk for it to work ?
Its already included in Ariela. You just need to install the py component on your server. For more details check GitHub - MCrissDev/HANotify: Android actionable notifications for Home Assistant and Ariela client
Thanks fore reporting the issue i will investigate it. About other issues i added them to my TODO list so i didn’t forget about.
Ionut
A new update was posted to play store that should fix this issue. Please let me know if its still reproducing.
Ionut
For the next big release, what kind of futures would you like to see in the application?
What i am currently working on:
- device tracker functionality
- new authentication support
I am waiting for your ideas wanting to make Ariela best Android Home Assistant client.
device tracker with location and battery status
Hello yrune,
That is already in progress and it should be available in maximum 1 week.
ok, I just purchase the pro app, not because I have any use for it at this state but because I like your enthusiastic development.
But one question, there was some talk of https support, I have https and it allways work, but I’ve noticed every couple of days I check the app (because of new version) I have to redo the setup. Also it will not discover my HA. I have to manually enter it. Is this because of https ?
Will do some notify testing now
I cannot get the notify to work. Just to be clear, in the instructions it says:
4. Install the HANotify.apk file onto your android device (or compile it in Android Studio).
but I’m supposed to skip this part, because it’s inluded in Ariela ?
I notice there is a config file with a token in my HA conf folder, so I assume there is some sort of connection. But simple nor advanced notifications work. The token config does list as “unnamed device” though, not the name I set in Ariela.
