What I would like to point out again:
Ariela is far ahead any other mobile solution, you’re giving an amazing and fast support, your solution is a real value add for HA and therefore should be from my point of view the! official mobile solution for HA.
Thanks for you’re great work. I hope, somebody of the core team will contact you regarding this.
The web UI pull-to-refresh feature still does not work properly. When I open the hassio menu item with all the add-ons I can scroll down ok ,but when I let go and try to scroll up the it won’t scroll but instead triggers the refresh feature.
I have to scroll down a bit to then scroll up In the same gesture to get back to the top.
And that workaround won’t even work if you’ve scrolled all the way to the bottom.
It is easy to fix, though. Just check the current scroll position of the webview and allow pull-to-refresh only when it is at the very top. Otherwise let it scroll.
Hehe, believe me that is not that easy fix
Still, you have a new option that allow disabling pull to refresh option until i figure it out how to fix it.
Hi Ionut, would it be possible to create something like a notification sensor that could send the latest phone notifications received from other apps to HA via MQTT or something? If you understand what I mean!
For example I get FIFA notifications when my team scores so if I could get this into home assistant I can create automations based on this
Yes, i just tried and its possible to do that. Ariela can send the notification title, notification message, and the application package name. Of course in order for this to work, you will have to give Ariela permission to read notifications.
