Sent log file via the app
App got stuck at some point (never ending refresh), added screenshot of kill app message
And got “Unable to enable Lovelace UI” when tried to enable it
Disconnect didn’t happen in this few minutes, that happens without any schedule, don’t know what to do to reproduce it.
Forgot to mention, when camera resolution is down, I get picture from front camera also
HI @Ionut, I moved from MQTT to MOBILE_APP and the tracking position is not working. I had to enable both see and mobile app to have sensor and position. It’s an issue or I’m missing something?
Hi Ionut, would it be possible to get a ‘Ignore self-signed certificates’ for the internal IP server connection?
Its not possible to get a legitimate cert for the ‘internal IP’ server address, and my ‘external IP’ server address is a letsencrypt one. It seems everytime I leave and come home, I need to re-accept the message that says its not a valid cert.
Being able to just accept it once, and never be informed again would be good.
If you publish the HA discovery messages ‘retained’ to the MQTT broker then the devices will be remembered in HA after restarts. If you also want the states persistent (based on last value posted to MQTT) then these too must be published ‘retained’ . Otherwise when HA is restarted it gets no auto discovery messages and can’t read state values.
word of warning to those using the “mobile_app sensors” with a pi:
if you enable the constantly changing sensors like the light, notifications, step counter, etc, it will create a lot of churn on the .storage/mobile_app file. I see the file changing every few seconds when I have those sensors enabled. MQTT might be a better option for sensors that change frequently.
under the “lovelace ui” view in Arielai i have to manually refresh the page for camera card to update. i also get a blank screen when clicking on the card. it probably depends on how our web proxy/ssl are set up.
it works better if you switch to use the “web ui” view in Ariela. camera cards will work almost like normal… with a slight bug mentioned below.
i configured my cameras cards to use “stream 1” which is a preview/low resolution stream set to near vga resolutions so it consumes very little data. it works just fine for quick peek via HA while on mobile data.
there is a slight bug with the video interface inside of Ariela however. somehow the “maximize/full screen” button (lower right corner while video stream is playing) is grayed out/disabled while playing video inside of Ariela interface. it works fine if i pull up the HA interface via browser.
… this is under the “web UI” view btw. it should give me pretty much the same lovelace ui view as via browser?
