After a few hours I get this result:
ebusctl find -d -v
dhw dhw_set_temp = =55.0
dhw timer_prog_10_day_part_2 = =55 55 55 55 55 55 55 55 55 55 55 55
dhw timer_prog_11_day_part_1 = =55 00 00 00 00 00 00 00 00 00 00 55
dhw timer_prog_12_day_part_2 = =55 55 55 55 55 55 55 55 55 55 55 55
dhw timer_prog_13_day_part_1 = =55 00 00 00 00 00 00 00 00 00 00 55
dhw timer_prog_14_day_part_2 = =55 55 55 55 55 55 55 55 55 55 55 55
dhw timer_prog_1_day_part_1 = =55 00 00 00 00 00 00 00 00 00 00 55
dhw timer_prog_2_day_part_2 = =55 55 55 55 55 55 55 55 55 55 55 55
dhw timer_prog_3_day_part_1 = =55 00 00 00 00 00 00 00 00 00 00 55
dhw timer_prog_4_day_part_2 = =55 55 55 55 55 55 55 55 55 55 55 55
dhw timer_prog_5_day_part_1 = =55 00 00 00 00 00 00 00 00 00 00 55
dhw timer_prog_6_day_part_2 = =55 55 55 55 55 55 55 55 55 55 55 55
dhw timer_prog_7_day_part_1 = =55 00 00 00 00 00 00 00 00 00 00 55
dhw timer_prog_8_day_part_2 = =55 55 55 55 55 55 55 55 55 55 55 55
dhw timer_prog_9_day_part_1 = =55 00 00 00 00 00 00 00 00 00 00 55
energymgr dhw_comfort_mode = (ERR: invalid position for 317c200002c028 / 0100)
energymgr dhw_comfort_temp = (ERR: invalid position for 317c2000026126 / 0100)
energymgr dhw_economy_temp = (ERR: invalid position for 317c2000026226 / 0100)
energymgr dhw_store_temp = (ERR: invalid position for 317c2000027017 / 0100)
energymgr dhw_thermal_cleansing_mode = (ERR: invalid position for 317c2000020b20 / 0100)
energymgr nuos_info1 = dhw_status=on;anti_legionella=on;dhw_comfort_mode= (ERR: argument value out of valid range for 77fe20200c0220010b20010f2000c02802 / )
energymgr nuos_info2 = dhw_comfort_temp=55.0;dhw_economy_temp=41.0
scan.7c = (ERR: invalid position for 317c07040
0 / 00)
My cfg-file looks like this atm:
r,energymgr,dhw_comfort_temp,DHW Comfort Temp,,7c,2000,6126,,s,IGN:1,,,,,,SIN,10,°C,,,,,,,,,,,,,,,,,,,,,,
r,energymgr,dhw_economy_temp,DHW Economy Temp,,7c,2000,6226,,s,IGN:1,,,,,,SIN,10,°C,,,,,,,,,,,,,,,,,,,,,,
r,energymgr,dhw_comfort_mode,DHW Comfort Mode,,7c,2000,c028,,s,IGN:1,,,,,,BCD,0=off;1=timed;2=always_on
r,energymgr,dhw_thermal_cleansing_mode,DHW Thermal Cleansing Function,,7c,2000,0b20,,s,IGN:1,,,,,,onoff
r,energymgr,dhw_store_temp,DHW Storage Water Temp,,7c,2000,7017,,s,IGN:1,,,,,,SIN,10,°C
b,energymgr,nuos_info1,Nuos Info 1,77,fe,2020,0220,dhw_status,s,onoff,,,,,s,IGN:2,,,,anti_legionella,s,onoff,,,,,s,IGN:3,,,,dhw_comfort_mode,s,BCD,0=off;1=timed;2=always_on,
b,energymgr,nuos_info2,Nuos Info 2,77,fe,2020,ca2a,ign,s,IGN:3,,,,dhw_comfort_temp,m,SIN,10,°C,,,m,IGN:2,,,,dhw_economy_temp,m,SIN,10,°C
r,dhw,dhw_set_temp,DHW set temp,77,fe,2010,6147,,s,U3N,10,°C,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_1_day_part_1,Timer Program part 1,77,fe,2051,0007,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_2_day_part_2,Timer Program part 2,77,fe,2051,1007,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_3_day_part_1,Timer Program part 1,77,fe,2051,0107,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_4_day_part_2,Timer Program part 2,77,fe,2051,1107,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_5_day_part_1,Timer Program part 1,77,fe,2051,0207,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_6_day_part_2,Timer Program part 2,77,fe,2051,1207,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_7_day_part_1,Timer Program part 1,77,fe,2051,0307,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_8_day_part_2,Timer Program part 2,77,fe,2051,1307,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_9_day_part_1,Timer Program part 1,77,fe,2051,0407,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_10_day_part_2,Timer Program part 2,77,fe,2051,1407,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_11_day_part_1,Timer Program part 1,77,fe,2051,0507,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_12_day_part_2,Timer Program part 2,77,fe,2051,1507,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_13_day_part_1,Timer Program part 1,77,fe,2051,0607,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
u,dhw,timer_prog_14_day_part_2,Timer Program part 2,77,fe,2051,1607,,s,HEX:12,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
So, it seems there is some progress, altough the most interesting one is of course the current temp, which seems to be completely unavailable (without asking the proper question on the bus) if I understand correctly…
