Arlec PC399HA Entity Configuration - Smart Plug Tuya Local
I’m hoping someone might be able to please help me. I have a bunch of Arlec Model PC399HYA (Tuya based) switches and power plugs installed in my house. I’ve recently purchased a smart plug with power metering and also recently made the switch to Tuya Local.
Ideally I’d like to know what all the attributes are, but I’d happily settle for the Current, Current Consumption and Voltage, as per the diagram. (Pretty sure that the voltage is Value 20)
Any help would be greatly appreciated.
Hi , did you get anywhere with this ?
Im stuck on the exact same issue.
Bring it up in TuyaSmart and compare the values found there ?
Yes I did by installing the Tuya V2 integration.
Hi @riccid - Although it looks like you’ve got it sorted, the ID values are:
Switch: 1
Current: 18
Power:19
Voltage: 20
Current, power and voltage all need to be scaled by 0.1 to give you the correct value.
Nice work, The only one I had an issue with was 18 Current - For the “Current (Amps)” I had to scale it by 0.001 for the correct Amp reading
Interesting, my version of HA wont let me enter a scale of 0.001. It stops at 0.1
hey - incase anyone else has this issue. Type 0.001 in notepad for example, copy. Then paste into the HA scaling factor :slight_smile:
I’ve been battling for hours to try and get Arlec GridConnect PC399HYA and PC191HA Smart Plug-in socket with energy meter recognised by TuyaLocal today.
The plug’s switch module was discovered easily, but I could not work out the right settings to get the energy/power monitors to work. I was going down custom-code rabbit-holes that didn’t need to be touched.
In the end, it was very, very simple - Everything was configured via the GUI with no custom YAML needed.
Summary:
Configure the existing switch entity to add the following IDs:
ID 1: Switch (already exists)
ID 18: Current (A) + Scaling factor 0.001 (Bug: must copy & paste this value into the UI)
ID 19: Power (W) + Scaling factor 0.1
ID 20: Voltage (V) + Scaling factor 0.1
Assumptions:
  • LocalTuya is already installed.
  • Your device has already been added to LocalTuya.
  • You can see and control the ‘Switch’ entity of the device.
Refer here for LocalTuya installation instructions:
Lots more detail in this thread too:
Step-by-step guide:
In Home Assistant, navigate to Settings > Devices & Services.
Open LocalTuya.
Click “Configure”.
Select “Edit a device
Screenshot 2023-12-29 150058
Select your Arlec Grid Connect Plug from the list
Screenshot 2023-12-29 150110
Tick “Add more entities in ‘edit device’ mode
Change the Entity Type Platform to “Sensor
Screenshot 2023-12-29 150146
Configure Entity as follows:
ID 18: Current (A)
Untick “Do not add any more entities
Screenshot 2023-12-29 150301
Repeat the Configure Entity process 2x more times.
After the 3rd (Voltage) entity is added, leave the “Do not add any more entities” ticked
Screenshot 2023-12-29 150438
Success!
Screenshot 2023-12-29 150444
Visit your “Devices” tab, and find the plug device
The device should now show the sensor values
Which you can click on and see the graphs
Click the cog to find additional configuration.
e.g. If needed, you can increase the display resolution if you have low-current devices like LED fairy lights.
That’s it!
Hope this helps.
Also Discovered the easiest way is to type:-
.1
then left arrow to move the Cursor to between the point & the one,
then type the two extra zeros.
Arlec PC191HA’s here, Common at Bunnings in Aus.
Thanks for detailing this, helped me get started. there have also been a couple of extra DPID’s to use/configure, not sure if they are new, or were always there.
I have found (using xZetsubou’s local Tuya) it is easier to create a template in /config/localtuya/templates/arlec.yaml and configure them all in one go when you add each device, as per this template:
- sensor:
    friendly_name: Voltage
    entity_category: diagnostic
    unit_of_measurement: V
    device_class: voltage
    scaling: 0.1
    platform: sensor
    icon: ''
- sensor:
    friendly_name: Power
    unit_of_measurement: W
    device_class: power
    scaling: 0.1
    platform: sensor
    icon: ''
- sensor:
    friendly_name: Current
    unit_of_measurement: A
    device_class: current
    scaling: 0.001
    platform: sensor
    icon: ''
- switch:
    friendly_name: Power Switch
    entity_category: None
    restore_on_reconnect: false
    is_passive_entity: false
    device_class: outlet
    platform: switch
    icon: ''
- number:
    friendly_name: Switch 1 Timer
    entity_category: config
    min_value: 0.0
    max_value: 86400.0
    step_size: 1.0
    unit_of_measurement: s
    scaling: 1.0
    platform: number
    icon: mdi:timer
- select:
    friendly_name: Power-on behavior
    select_options:
      'off': 'Off'
      'on': 'On'
      memory: Remember last state
    platform: select
    icon: ''
