Getting following message when trying to setup my Arlo into HA
Nay help on whats wrong would be apreciated
Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a block mapping in "/home/homeassistant/.homeassistant/configuration.yaml", line 1, column 1 expected <block end>, but found '<block sequence start>' in "/home/homeassistant/.homeassistant/configuration.yaml", line 130, column 2
- id: disarm_arlo_when_arriving
alias: Set Arlo cameras to Home mode when arriving
platform: state
entity_id: group.family
to: home
service: alarm_control_panel.alarm_arm_home
entity_id: alarm_control_panel.kamera_server
platform: state
to: not_home
service: alarm_control_panel.alarm_arm_away
platform: state
#Arlo
arlo:
username: XXX
password: XXX
scan_interval: 60
alarm_control_panel:
- platform: arlo
- platform: arlo
monitored_conditions:
- captured_today
- last_capture
- total_cameras
- battery_level
- signal_strength
camera:
- platform: arlo
ffmpeg_arguments: '-pred 1 -q:v 2'
group:
family:
entities:
- device_tracker.robbans_iphone
- device_tracker.helenas_iphonex
platform: state
to: home
platform: state
to: not_home
platform: state
You’re all over the board here. You really need to read and learn yaml. It’s clear you don’t understand the spacing or how the fields work. I suggest reading the docs to figure it out
You are missing the automation section.
Your spacing is off just about everywhere. Please read and understand yaml spacing.
You’re duplicating automations without adding a new bullet.
You have half an automation at the end with no actions.
#Arlo
arlo:
username: XXX
password: XXX
scan_interval: 60
- platform: arlo
- platform: arlo
- captured_today
- last_capture
- total_cameras
- battery_level
- signal_strength
camera:
- platform: arlo
group:
family:
entities:
automation:
platform: state
to: home
- id: something
platform: state
to: not_home
