Hello !!
I have 2 Arlo Pro 2 cameras and i set up the alarm panel with arlo as described below
alarm_control_panel:
- platform: arlo
home_mode_name: 'Home'
away_mode_name: 'Away'
I am using Hassio and HA 0.65.3
After a few hours, the alarms go to Unknown state and never recover.
I can see this in the error log when the issue starts…
2018-03-14 19:11:13 ERROR (MainThread) [homeassistant.helpers.entity] Update for alarm_control_panel.home fails
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 601, in urlopen
chunked=chunked)
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 387, in _make_request
six.raise_from(e, None)
File “”, line 2, in raise_from
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 383, in _make_request
httplib_response = conn.getresponse()
File “/usr/lib/python3.6/http/client.py”, line 1331, in getresponse
response.begin()
File “/usr/lib/python3.6/http/client.py”, line 297, in begin
version, status, reason = self._read_status()
File “/usr/lib/python3.6/http/client.py”, line 258, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), “iso-8859-1”)
File “/usr/lib/python3.6/socket.py”, line 586, in readinto
return self._sock.recv_into(b)
File “/usr/lib/python3.6/ssl.py”, line 1009, in recv_into
return self.read(nbytes, buffer)
File “/usr/lib/python3.6/ssl.py”, line 871, in read
return self._sslobj.read(len, buffer)
File “/usr/lib/python3.6/ssl.py”, line 631, in read
v = self._sslobj.read(len, buffer)
ConnectionResetError: [Errno 104] Connection reset by peer
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 440, in send
timeout=timeout
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/lib/python3.6/site-packages/urllib3/util/retry.py”, line 357, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/lib/python3.6/site-packages/urllib3/packages/six.py”, line 685, in reraise
raise value.with_traceback(tb)
chunked=chunked)
response.begin()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 204, in async_update_ha_state
yield from self.async_device_update()
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 327, in async_device_update
yield from self.hass.async_add_job(self.update)
File “/usr/lib/python3.6/asyncio/futures.py”, line 332, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 250, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/alarm_control_panel/arlo.py”, line 83, in update
mode = self._base_station.mode
File “/usr/lib/python3.6/site-packages/pyarlo/base_station.py”, line 298, in mode
if self.is_in_schedule_mode:
File “/usr/lib/python3.6/site-packages/pyarlo/base_station.py”, line 320, in is_in_schedule_mode
mode_event = self.publish_and_get_event(resource)
File “/usr/lib/python3.6/site-packages/pyarlo/base_station.py”, line 105, in publish_and_get_event
self._subscribe_myself()
File “/usr/lib/python3.6/site-packages/pyarlo/base_station.py”, line 85, in _subscribe_myself
publish_response=False)
File “/usr/lib/python3.6/site-packages/pyarlo/base_station.py”, line 189, in __run_action
extra_headers={“xCloudId”: self.xcloud_id})
File “/usr/lib/python3.6/site-packages/pyarlo/init.py”, line 142, in query
req = self.session.post(url, json=params, headers=headers)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 555, in post
return self.request(‘POST’, url, data=data, json=json, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 508, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 618, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 490, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
Any idea why ?
If i restart, starts working again for a few hours…
Thanks!!!
