Arlo - not showing anything at all - not even a Control Panel?
Hi everyone,
I’m trying to implement the Arlo components into my Home Assistant.
Currently I’m running the Hass.io on my Rpi3 Model B+ (newest) with the 32-bit installer.
What I’ve done so far is to try following the components guide on the home assistant webpage, but no luck.
Here is my config:
#Video Enabled
ffmpeg:
#Survelliance
    arlo:
      username: xxxxxxxxxxxxxxxxxxxx
      password: xxxxxxxxxxxxxxxxxxx
    alarm_control_panel:
      - platform: arlo
        home_mode_name: 'disarmed'
        away_mode_name: 'armed'
    camera:
      - platform: arlo
        ffmpeg_arguments: '-pred 1 -q:v 2'
The only thing that shows on my webinterface is 4 grey lines with the names of the cameras stating “Picture is not available”.
In my lovelace ui it doesn’t show anything at all.
Also I will of course put the username and password in another file, but for now I just want to get it up and running.
What am I doing wrong :frowning:?
There is some problem whit the Arlo component right now, a fix is ongoing and hopefully will be in next release
https://github.com/home-assistant/home-assistant/issues/17427#issuecomment-431754186
Oh thanks for the update - I didn’t see that one!
Fingers crossed!
But does the config look correct though?
I looks right to me, you can take a look at mine if you won’t to compare
https://github.com/Nicxe/HASS.io/blob/master/packages/arlo.yaml
A workaround can be to use IFTTT to arm/disarm and trigger on motion. I changed to use that when the Arlo component started having issues.
Arming and disarming is just them matter of calling a service:
https://github.com/joch/home-assistant-config/blob/master/automation/home/alarm.yaml#L14
To trigger when Arlo detects motion, you can setup an input_boolean and make a web request to set it from IFTTT.
https://github.com/joch/home-assistant-config/blob/master/automation/home/alarm.yaml#L288
Is this still a problem? New user (as of today) using the latest everything (as of today) getting all the sensor telemetry however no video (displays “Image not Available” in the dashboard, and "2018-12-26 19:58:55 ERROR (MainThread) [homeassistant.components.camera.arlo] Video not found for Back Door Internal. Is it older than 30 days?
" in the log)
I think is older than that - but I must admit that I haven’t added it again.
I’m not sure whether it is stable again or not.
Hey joch,
Maybe you can help me.
I created a IFTTT account, added a webhook and created two:
If Maker Event "HA_Arm_Arlo", then Arm Arlo
If Maker Event "HA_Arlo_Disarm", then Disarm Arlo
In my confguration I’ve set up the ifttt component and added the API key:
# IFTTT
ifttt:
  key: !secret ifttt_api
My automation looks like this:
- alias: '[Alarm/Arlo] Armed & Notification'
    - platform: state
      entity_id: alarm_control_panel.house
      to: 'armed_away'
### Arm Arlo - IFTTT ###
  - service: ifttt.trigger
    data: {"event":"HA_Arlo_Arm"}
But Arlo never gets armed and I can see that on the IFTTT page it states that the applet never has been triggered.
What am I doing wrong?
That actually looks correct! Is there anything in the home assistant log?
OMG! I had a typo.
I was calling:
While the webhook was stated with:
Sorry for that :blush:
Good catch! I’m glad you got it working. :slight_smile:
Has anyone managed to see recorded images?
Mine stoped working several months ago, not only show up as grey bars.
Is playback of last recorded video no longer a function?
