Arlo Q camera no longer working after 0.72 upgrade
I started receiving these errors after the 0.72 upgrade, does anyone have any ideas on what to do or should I be putting in a bug report?
Unable to prepare setup for platform camera.arlo: Could not setup all dependencies.
8:55 AM setup.py (ERROR)
Unable to setup dependencies of camera.arlo. Setup failed for dependencies: arlo
Unable to prepare setup for platform sensor.arlo: Could not setup all dependencies.
Unable to setup dependencies of sensor.arlo. Setup failed for dependencies: arlo
Setup failed for arlo: Component failed to initialize.
Trying to setup Arlo for the first time and I receive the same errors.
I get the same thing as well, I just have an Arlo baby camera and was curious to see the new integration of the sensors/lights after looking over the Python library of what it can do.
Same problem here , running 0.72.1.
Same problem using Aro Q Plus, was working with 0.71. I have created a error report. The Arlo Component update in 0.72 did brake it.
https://github.com/home-assistant/home-assistant/issues/15026
Any news on this?
Is there anything new to report?
I had the same issue, sent a pull request already (https://github.com/home-assistant/home-assistant/pull/16529), hopefully it can fix the problem.
