Error handling message: Unknown error
File "/usr/src/app/homeassistant/components/websocket_api/decorators.py", line 17, in _handle_async_response
await func(hass, connection, msg)
File "/config/custom_components/aarlo/camera.py", line 434, in websocket_stop_activity
stopped = await camera.async_stop_activity()
File "/config/custom_components/aarlo/pyaarlo/camera.py", line 451, in stop_activity
base=self.base_station,
File "/config/custom_components/aarlo/pyaarlo/device.py", line 174, in base_station
return self._arlo.base_stations[0]
IndexError: list index out of range
I am on Home Assistant 0.97.1, Aarlo v0.0.7-test01 but v0.5.5 gave the same errors, and lovelace card v0.0.10.
After a while, not sure exactly how long, my home assistant hangs and the page doesn’t respond or reload until I restart the docker container. Not sure if it has to do with this error or something else. Just extra info.
Was there any debug just before the crash? Something like stop_activity for XXX with a camera ID after it? If there isn’t and it’s easily reproducible can you turn on debug?
Is there anyone who can help me out. I am trying to get the custom lovelace card working, but not matter what i do, i keep getting the error: Custom element doesn’t exist: aarlo-glance.
I have tried absolutely everything under the sun, but continually get this error. Can anyone confirm if there anything else whatsoever that you need to do apart from installing the HACS lovelace package and then entering the below into ui-lovelace.yaml? I have never installed any other custom cards (well at least never got them working). Is there something else that you need to do to get custom cards setup?
@Bruskey27 The resources entry looks correct but I use Config UI/Raw Config Editor to modify my layout and not editing ui-lovelace.yaml directly. I find the caching can be aggressive so try forcing a web page refresh - SHIFT + CTRL + R on Chrome for example - to get everything reloaded.
I have tried refreshing and still the same error. I struggle to understand how it can be a caching issue when the issue is occurring on multiple browsers. I am seeing the same issue on both chrome on my android phone as well as in firefox.
Can you confirm what you mean by using the Config UI/Raw Config Editor? Is that just adding those lines directly to the lovelace card rather than putting it into the config file?
@Bruskey27 Click on the three dots on the tip right then select ‘Configure UI’. It will give you a warning about controlling the UI (I can’t remember the exact wording), click to continue and then click on the three dots again and select ‘Raw Config Editor’.
But I’m sure it should work from the ui-lovelace.yaml. Do the browser developer tools show anything suspicious?
Still the same thing. I am struggling to understand how this error suggests it’s a caching issue? Anything to do with the “custom_cards.json” file? Why is that in the repository of files yet I dont have that anywhere?
My previous experiences here always end up having extra steps or prerequisites which seem to be assumed as you know about them and I end up having to dig around to find the missing steps. Is this the case here as well?
Excellent. There was a timing issue, I guess it was related to that. I was asking because somebody posted a bug report on github with a similar back trace.
Using Google Chrome 76.0.3809.100 (Official Build) (64-bit) if that helps
hass-aarlo version 0.0.7
custom card verson 0.0.10
The card configuration below produces the error, but no matter what i put in:
entity: camera.aarlo_front_door
show:
- motion
type: 'custom:aarlo-glance'
@sherrell Good news! I finally got it working! I had to put it in the Raw Config editor section like you suggested. I tried that the other day without luck, but persisted and i can see the card now. Looks like there may be an issue then with using ui-lovelace.yaml?
Excellent. Glad it’s working for you. The UI had gotten easier to use because getting the card to refresh on mobile on older versions was damn near impossible.
