Hi Steve,
I have just upgraded to 0.7-reconnect from the previous but now I got weird scenarios:
not all sensors do populate only 1/5 batteries from the regular base has a state, the others have an unknown state.
all the additional sensors from the baby cam no longer work at all - dont get created, temperature, humidity, air quality unless I also set the sensor to
- platform: aarlo
monitored_conditions:
- last_capture
- total_cameras
- battery_level
- captured_today
- signal_strength
- air_quality
- humidity
- temperature
previously I didnt had any monitored conditions which I assume did allow to create whatever was there to report on now I need to set it to have them appear in the first place but no values are being read.
attribution: Data provided by arlo.netgear.com
brand: Netgear Arlo
friendly_name: Humidity Nursery
model: ABC1000
unit_of_measurement: %
icon: mdi:water-percent
device_class: humidity
further streaming seems broken now:
Exception in thread stream_worker:
File "/usr/lib/python3.6/threading.py", line 916, in _bootstrap_inner
self.run()
File "/usr/lib/python3.6/threading.py", line 864, in run
self._target(*self._args, **self._kwargs)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/stream/worker.py", line 49, in stream_worker
container = av.open(stream.source, options=stream.options)
File "av/container/core.pyx", line 275, in av.container.core.open
File "av/container/core.pyx", line 227, in av.container.core.Container.__cinit__
File "av/container/core.pyx", line 129, in av.container.core.ContainerProxy.__init__
File "av/container/core.pyx", line 195, in av.container.core.ContainerProxy.err_check
File "av/utils.pyx", line 105, in av.utils.err_check
av.AVError: [Errno 5] Input/output error: 'rtmps://vzwow94-z1-prod.ar.arlo.com:80/vzmodulelive?egressToken=[----token----]&userAgent=web&cameraId=[part1]_[part2]'
