I’ve an Odroid N2+ that I’m thinking to put home-assistant-OS on. Currently I’m using Debian on my odroid and thus I can run docker etc on.
I read that ha-osalso uses Debian and I’d assume installing docker, pihole there is no problem?
Do I miss out on any functionality going from Debian/core to HA-os?
Is updates to the OS similar to regular Linux distributions? Or will it always start from a blank slate (like immutable OS)
You read incorrectly. It is a Build-root system, very minimal, locked down, and you have very limited access to it. It is an “appliance”.
That would be a mostly incorrect assumption.
The only access you have to extra containers when using HAOS is through “add-ons”. PiHole and AdGuard are available as are a lot of other core and third party containerised add-ons.
OS updates are released form time to time and are managed through the HA graphical user interface.
