Can’t figure it out. Seems everything is in place but somehow just doesn’t work. Without the template with just light_on and light_off everything seems fine
You’ll need to expand on what specifically isn’t working for me to help further.
But what jumps out at me is that you’re setting max brightness for when left and right lights are both off and also when left is off and right is on. But 0 brightness when both left and right are on.
It seems strange to me that you’re missing the case of left on and right off, and also that you’re setting 0 brightness when both lights are on. Are you sure the logic represents what you’re expecting?
Ok should go into more detail. Seems like with recent releases of HA setting the brightness to 0 switches off the lights. So if you have two or more light you want to control with a single button - you can skip the hassle of writing multiple light.toggle automations combine everything into just one simple one. And this is what i am trying to achieve. One z-wave button controls left and right light strips. So if both off - turn them on. If the right one is on (i have a separate scene for it) turn them on. If they are on - switch them off
Ok makes more sense although I think you’re missing the case of left off and right on (unless maybe that’s not feasible with a separate scene). So what specifically is not working. Or put another way, what is the present behavior?
data_template was deprecated in favor of simply data many versions ago.
I’ve been using Home Assistant since 2018 and I don’t recall examples with a line-continuation character next to data_template. It’s news to me that it ever worked that way.
