As {% if %} action in an automation: is entity_id part of group of entity_ids
I need to use a version of the following code as the start of my action sequence. Is there a correct way to format this. See triggers (later) for reference.
Again my goal is to be able to ask if a certan entity_id is one of a named group of them, referenced by trigger.entity_id (refer to my value template)
    - service: input_text.set_value
      data_template:
        entity_id: "input_text.{{trigger.entity_id.split('.')[1].split('_')[0]}}_motion_state"
        value: >
          {% if trigger.entity_id in ['sensor.david_distance_to_home', 'sensor.renata_distance_to_home', 'sensor.cynthia_distance_to_home'] %}
- alias: Set distance input when state change
    - platform: state
      entity_id:
        - sensor.david_distance_to_home
        - sensor.renata_distance_to_home
        - sensor.cynthia_distance_to_home
    - platform: numeric_state
      entity_id: sensor.david_dist_update
      above: 5
      for:
        seconds: 30
      entity_id: sensor.renata_dist_update
      above: 5
      for:
        seconds: 30
      entity_id: sensor.cynthia_dist_update
      above: 5
      for:
        seconds: 30
      data_template:
        value: >
          {{ trigger.entity_id in ['sensor.david_distance_to_home', 'sensor.renata_distance_to_home', 'sensor.cynthia_distance_to_home'] }}
Unless I am missing something, that is about the same as I had with the exception that this iss a {{ }} instead of the {% if… %}
here is the whole code for context.
    - platform: state
      entity_id:
      above: 5
      for:
        seconds: 30
      above: 5
      for:
        seconds: 30
      above: 5
      for:
        seconds: 30
  mode: queued
#    - service: notify.mobile_app_davids_phone
#      data_template:
#        title: "{{ trigger.entity_id }}"
#        message: "{{ trigger.to_state.state }}"
      data_template:
        value: >
              {% if trigger.entity_id == 'sensor.david_distance_to_home' %}
                  {% if states('sensor.david_distance_to_home') > 0.25 %}
                      {% if trigger.from_state.state > trigger.to_state.state %}
                        {{ 'Towards' }}
                      {% elif trigger.from_state.state < trigger.to_state.state %}
                        {{ 'Away From' }}
                      {% else %}
                        {{ 'Stationary 1' }}
                      {% endif %}
                  {% else %}
                    {{ 'Arrived Home 1' }}
                  {% endif %}
              {% elif trigger.entity_id == 'sensor.renata_distance_to_home' %}
                  {% if states('sensor.renata_distance_to_home') > 0.25 %}
                        {{ 'Towards' }}
                        {{ 'Away From' }}
                      {% else %}
                      {% endif %}
                  {% else %}
                  {% endif %}
              {% else %}
                  {% if states('sensor.cynthia_distance_to_home') > 0.25 %}
                      {{ 'Towards' }}
                      {{ 'Away From' }}
                    {% else %}
                    {% endif %}
                  {% else %}
                  {% endif %}
              {% endif %}
          {% else %}
              {% if trigger.entity_id == 'sensor.david_dist_update' %}
                  {% if states('sensor.david_distance_to_home')|float <= 0.25 %}
                    {{ 'Arrived Home 2'}}
                  {% else %}
                    {{ 'Stationary 2' }}
                  {% endif %}
              {% elif trigger.entity_id == 'sensor.renata_dist_update' %}
                  {% if states('sensor.renata_distance_to_home')|float <= 0.25 %}
                    {{ 'Arrived Home 2' }}
                  {% else %}
                  {% endif %}
              {% else %}
                  {% if states('sensor.cynthia_distance_to_home')|float <= 0.25 %}
                  {% else %}
                  {% endif %}
              {% endif %}
          {% endif %}
