AS3935 Lightning sensor - some possible coding issues
While testing with a DFRobot Gravity Lightning Sensor I came across some possible issues with the current ESPHome AS3935 component.
It looks like some of the Configuration variables do not allow the full range to be set.
According to the AS3935 Datasheet The noise_level variable has a possible range of 0 to 7 (or 000 to 111 in binary), but in the ESPHome component it can only be set from 1 to 7, missing the most sensitive setting of 0.
From the Datasheet:
ESPHome_AS3935_NoiseLevel_Datasheet
In the ESPHome configuration editor:
ESPHome_AS3935_NoiseLevel-0
In the ESPHome as3935.cpp code on Github:
ESPHome_AS3935_NoiseLevel_code
Similar, according to the AS3935 Datasheet The spike_rejection variable has a possible range of 0 to 11, but in the ESPHome component it can only be set from 1 to 11.
And according to the AS3935 Datasheet The watchdog_threshold variable has a possible range of 0 to 10, but in the ESPHome component it can only be set from 1 to 10.
I plan to report an issue about these points on Github, but to be sure my findings are correct I would appreciate to get some feedback first from other users.
Since I did not get any response on my initial post I assume I was right, so I have reported this issue on GitHub:
ESPHome AS3935 Lightning sensor Component - incorrect variable range restrictions #6110
