Ask again Cloudflaire tunnel work but no access from outside
sorry to ask again here
I no longer have access to my home from outside.
My network connection looks like this:
Own domain: mydomain.de
Tunnel: Cloudflire
My PC is on the same network as the internet Fritzbox
I uninstalled Cloudflaire and recreated the connection. everything looks good in Cloudflaire.
However, if I want to access it from outside using the external web address, Homeassistant blocks it
my Configuration.yaml looks like this
homeassistant:
  auth_providers:
   - type: trusted_networks
     trusted_networks:
       - 192.168.2.0/24
       - 192.168.1.0/24
       - ff00::/8
     allow_bypass_login: true
  latitude: 49.460983
  longitude: 11.061859
  elevation: 430
  unit_system: metric
  currency: EUR
  country: DE
  time_zone: "Europe/Berlin"
  external_url: "https://www.mydomain.com"
  internal_url: "http://homeassistant.local:8123"
  allowlist_external_dirs:
    - "/config/tmp"
    - "/config/tmp/Cameras/snapshots/reolink_E1_Zoom"
    - "/config/www/cards"
    - "/config/www"
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.30.33.0/24
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
I can’t see and find the auth error!
Do you see him or do you still need dates?
Oh yes:
Even with my domain provider, when I reinstalled Cloudflaire, I also entered the new name servers that were already active… all to no avail
I think I set something wrong on the home assistant, I just don’t know where…
there the error what i get
Unable to fetch auth providers. https://ha.mydomain.de/?auth_callback=1
the subdomain "ha" is also regsitrated in cloudflaire ... all from mydomain.de looks in cloudflaire ok,,, but ha blocked and i don't know why
maybe that is important too
in my local network i get also sometimes login problems with homeassistant.local:8123…
now work that but if i try same second the local IP like 192.168.2.2:8123 i get that
same same auth problme like ha.mydomain.de and same like mobile-app…
Where else can I look? My configuration yaml looks clean
i try now to check configuration.yaml again i get same error but by the last refresh (ha.mydomain.de auth error… i refreshed this side ) i get this error
Error 1033 Ray ID: 86ab901f4a6d8c15 • 2024-03-27 01:21:19 UTC
Argo Tunnel error
What happened?
You've requested a page on a website (ha.mydomain.de) that is on the Cloudflare network. The host (ha.mydomain.de) is configured as an Argo Tunnel, and Cloudflare is currently unable to resolve it.
What can I do?
If you are a visitor of this website:
Please try again in a few minutes.
If you are the owner of this website:
Ensure that cloudflared is running and can reach the network. You may wish to enable load balancing for your tunnel.
now works all fine… is use now a other domain and take it again now works all fine!
This all you need in your configuration.yaml for Cloudflared. Try removing the trusted networks settings temporarily.
http:
  trusted_proxies:
     - 172.30.33.0/24
Does your Cloudflared addon config have the correct information?
Is your Cloudflare tunnel settings setup through ZeroTrust?
i check that feeling like 1000 times. I don’t find any differenc to 100 samples in the internet
This System works maybe 2 years long without any other configuration…
i do anything but i don’t know what.
i cinfigure a subdomain-name like HA.mydomain.de … now connect the tunnel to mydomain.de and works…
So you are up and running? The translation to English is not clear.
The problem might be, I don’t even know if it was the Cloudflare connection.
Example:
When I couldn’t log in externally to the HA system, my Loker access also had problems from time to time.
So I was just able to log in with homeassistant.local:8123 and in the second browser tab I tried to log in with the IP 192.168.2.2:8123 and the login was not accepted!
So I’m not entirely sure whether the actual problem has been fixed at all
yes, i think so… i take the configuration over zeroTrust
but my first cloudflaire tunnel… i’m not sure i configure this over ZeroTrust…
