Ask Google Home if anyone is home (presence)
just started to use hass.io.
I set up the presence for 4 family members with nmap.
In the startscreen I see who is at home and who is away, so that works great.
I also setup the Hassio-cloud and bound to google assistant.
I’d like to ask the Google assistant:" is Ralf at home?" or something alike.
Is that possible and what additional configuration should I do?
Thanks in advance for your help
Hi. Did you ever do this?
I’d like to do the same :slight_smile:
“is Ralf at home?” Could be a Google home routine that sets a boolean to true in Home Assistant and returns a TTS message.
The issue is to return the TTS message to the correct speaker/device.
Why not do it with IFTTT setup with a Webhook and a script in HA?
That works to but you introduce another point of failure.
Google Assistant => Home Assistant
Vs
Google Assistant => IFTTT => Home Assistant.
True.
I’ve only just started playing with scripts today. Couldn’t get it to work but I figured it out.
I agree it is another point of failure but I’ve really struggled to get the Google integration to work so until then IFTT, webhooks and scripts for me.
