Asking Alexa for Information with Node-Red
That’s my Way to Query Home-Assistant Sensor data with Alexa:
  • Create Dummy Light Object with NodeRed
  • Create Alexa Routine to set the Dummy Light to 10%
  • Create Script “Speak Sensor” to use TTS to send to Alexa current Sensor Data (Temp and Humidy)
  • Use NodeRed to if Dummy Light Object was Triggert to 10% Percentage
    and call “Speak Sensor” Script.
Why use This?
Just Add a Alex Routines to use to set different Percentages to query Other Sensor Data.
You need:
service: notify.alexa_media_kuche_alexa
  message: >-
    Die Feuchtigkeit ist {{states('sensor.5_in_1_pir_motion_sensor_humidity')
    }}%  bei {{states('sensor.5_in_1_pir_motion_sensor_air_temperature') }}
    Grad.
    type: tts
