Hi there!
I trigger some HA scripts via Alexa (Haaska) and the output of that scripts is a tts via Alexa.
I want that the tts output arrives from the Alexa device i used to trigger the script. Any idea?
Hi there!
You can do this pretty easily by using the Alexa Media Player (AMP) custom component available in HACS and setting up a Last Called Alexa sensor (Examples: Automation · custom-components/alexa_media_player Wiki · GitHub)
You can find two methods for Room Aware scripts using the Last Called Alexa sensor in the AMP wiki (Examples: Automation · custom-components/alexa_media_player Wiki · GitHub)
