Hi everybody,
I am currently setting up a fresh instance of Home Assistant and want to assign everything to its appropriate area. Please look at the attached screenshot:
Example entities:
- input_number.arbeitszimmer_heizung_00
- input_datetime.arbeitszimmer_heizung_00
- input_number.arbeitszimmer_heizung_01
- input_datetime.arbeitszimmer_heizung_01
While I can select multiple entities (it would not let me select automation.arbeitzimmer_00
when I tried to), this only gives me the options
- activate selected
- deactivate selected
- hide selected
- delete selected
However, I would like to assign all these entities to area_id: Arbeitszimmer
. Just for the sake of it. Everything works fine, it wouldn’t make a difference whether I do this or not (as far as I can see at the moment). But I’d still like to to make it easier to filter things, to see everything that is assigned to Arbeitszimmer
, for example; I could just click on SETTINGS > AREAS > and see what has to do with it.
When I add an integration
, this happens automatically: it prompts me for an area, I assign it > all entities that came with this integration are assigned to an area. However, these manually created input_number
, input_datetime
, or really any manually created entity (my “manually”, I mean via *.yaml
file) will not have an area assigned.
I can do this manually by clicking each individual entity and assign an area; but is there a better/faster way? This is the documentation for input_number
; there is no option to assign an area here. Is there a bulk way to do this that I just not haven’t found? Via UI or yaml doesn’t matter, as long as I can assign all entities to their appropriate rooms without doing it manually for each individual one
Thank you in advance for your input.
