I restarted my Hass.io instance, and it doesn’t seem to work.
I’ve since then assigned a static lease on this Hassio instance, but since I have a 1 day lease time, I’d like to speed up the process a little bit, and use the static IP I want.
I’m starting to think that I have to use a USB key with the my-network file…
Thanks for your answer ! I’ve done that, but it doesn’t seem to get the good IP address (I’m thinking it’s because of the lease time of 1 day, maybe it won’t work until that lease time has expired). That’s why I wanted to force it…
I have never touched the lan config in HA. Maybe you should set the IPv4 address to auto not manual… Also make sure you have the right MAC address reserved. I have never ever had an issue with a router reserving an IP address for a client unless some other device has/is using it and then you remove that device from the network and fix the reservation in the router (deleting the other device) and then restarting the device(s).
Well thanks for your help, I managed to solve my problem by disconnecting the network adapter in esxi, booting again, stopping again, and connecting the network adapter. I now have the ip I set in the static ip section on my router.
