Assist Microphone & USB conference mic/speaker
Yesterday I received an USB conference mic/speaker to use it connected at the miniPC that is hosting my home assistant.
I’m running latest HA OS and 2024.4.4
As soon as I connected it, it’s been recognized and I setup it to be my assist microphone input and output.
This is the device:
The voice pipeline is working fine and if I connect an usb headset to the minipc, it works.
But this conference usb/speaker is not working, this is what I see in the logs of the Assist Microphone extension:
[08:49:11] INFO: Service exited with code 256 (by signal 15)
s6-rc: info: service assist_microphone successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Aborted by signal Terminated...
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service assist_microphone: starting
s6-rc: info: service assist_microphone successfully started
s6-rc: info: service discovery: starting
DEBUG:root:Namespace(mic_uri=None, mic_command='arecord -r 16000 -c 1 -f S16_LE -t raw', mic_command_rate=16000, mic_command_width=2, mic_command_channels=1, mic_command_samples_per_chunk=1024, mic_volume_multiplier=1.0, mic_noise_suppression=1, mic_auto_gain=1, mic_seconds_to_mute_after_awake_wav=0.5, mic_no_mute_during_awake_wav=False, mic_channel_index=None, snd_uri=None, snd_command='aplay -r 16000 -c 1 -f S16_LE -t raw', snd_command_rate=16000, snd_command_width=2, snd_command_channels=1, snd_volume_multiplier=1.0, wake_uri=None, wake_word_name=[], wake_command=None, wake_command_rate=16000, wake_command_width=2, wake_command_channels=1, wake_refractory_seconds=5.0, vad=False, vad_threshold=0.5, vad_trigger_level=1, vad_buffer_seconds=2, vad_wake_word_timeout=5.0, event_uri=None, startup_command=None, detect_command=None, detection_command=None, transcript_command=None, stt_start_command=None, stt_stop_command=None, synthesize_command=None, tts_start_command=None, tts_stop_command=None, tts_played_command=None, streaming_start_command=None, streaming_stop_command=None, error_command=None, connected_command=None, disconnected_command=None, awake_wav='/usr/src/sounds/awake.wav', done_wav='/usr/src/sounds/done.wav', uri='tcp://0.0.0.0:10700', name='assist microphone', area=None, no_zeroconf=True, zeroconf_name=None, zeroconf_host=None, debug_recording_dir=None, debug=True, log_format='%(levelname)s:%(name)s:%(message)s')
INFO:root:Ready
DEBUG:root:Connecting to mic service: ['arecord', '-r', '16000', '-c', '1', '-f', 'S16_LE', '-t', 'raw']
DEBUG:root:Connecting to snd service: ['aplay', '-r', '16000', '-c', '1', '-f', 'S16_LE', '-t', 'raw']
INFO:root:Connected to services
DEBUG:root:Using webrtc audio enhancements
DEBUG:root:Connected to mic service
Recording raw data 'stdin' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
[08:49:17] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
DEBUG:root:Server set: 4204645662161
INFO:root:Connected to server
INFO:root:Streaming audio
DEBUG:root:Event(type='run-pipeline', data={'start_stage': 'wake', 'end_stage': 'tts', 'restart_on_end': True, 'snd_format': {'rate': 16000, 'width': 2, 'channels': 1}}, payload=None)
DEBUG:root:Ping enabled
WARNING:root:Did not receive ping response within timeout
DEBUG:root:Server disconnected
INFO:root:Disconnected from server
ERROR:asyncio:Task exception was never retrieved
future: <Task finished name='wyoming event handler' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.11/dist-packages/wyoming/server.py:31> exception=ConnectionResetError(104, 'Connection reset by peer')>
  File "/usr/local/lib/python3.11/dist-packages/wyoming/server.py", line 37, in run
    event = await async_read_event(self.reader)
  File "/usr/local/lib/python3.11/dist-packages/wyoming/event.py", line 79, in async_read_event
    json_line = await reader.readline()
  File "/usr/lib/python3.11/asyncio/streams.py", line 545, in readline
    line = await self.readuntil(sep)
  File "/usr/lib/python3.11/asyncio/streams.py", line 637, in readuntil
    await self._wait_for_data('readuntil')
  File "/usr/lib/python3.11/asyncio/streams.py", line 522, in _wait_for_data
    await self._waiter
  File "/usr/lib/python3.11/asyncio/selector_events.py", line 995, in _read_ready__data_received
    data = self._sock.recv(self.max_size)
ConnectionResetError: [Errno 104] Connection reset by peer
DEBUG:root:Server set: 4288002298056
    await self._waiter
DEBUG:root:Server set: 4539315871480
Any idea on hoe to fix this ?
Exactly same issues on my side.
Did you solve the problem?
BR
Unfortunately no :frowning:
I have an identical log output from the ‘local microphone’ add on. I’m using a Yeti Blue Stereo USB microphone. Running latest HA and add ons. I’m finding the results of Whisper speech to text quite variable. Sometimes it works perfectly, other times I’m speaking the same simple words (e.g. turn on lounge light) and the recognised text is complete nonsense. Not sure if it’s related to the stack trace. I’d be interested to hear how it’s working for others with this same error message.
Unfortunately, I am experiencing the same issue. My speakerphone is completely deaf.
I am struggling with my USB audio device for weeks already, without any hope for solution. Also I rose an issue for the Home Assistant core but after 4 days no-one even reacted to it. So, I am completely lost…
If anyone could come up with any hint, I would be very happy…
year of the voice…more like year of the deaf. Over a year later. My usb mic won’t work with assist either.
