I’m trying to use Creative Sound Blaster AXX SBX 8 with Assist Microphone addon. When I start the addon wakeword is properly detected, assistant responds with configured voice, but then wakeword is not detected anymore. I need to restart Assist Microphone addon to make it work again. Here are the logs:
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service assist_microphone: starting
s6-rc: info: service assist_microphone successfully started
s6-rc: info: service discovery: starting
DEBUG:root:Namespace(mic_uri=None, mic_command='arecord -r 16000 -c 1 -f S16_LE -t raw', mic_command_rate=16000, mic_command_width=2, mic_command_channels=1, mic_command_samples_per_chunk=1024, mic_volume_multiplier=1.0, mic_noise_suppression=0, mic_auto_gain=0, snd_uri=None, snd_command='aplay -r 16000 -c 1 -f S16_LE -t raw', snd_command_rate=16000, snd_command_width=2, snd_command_channels=1, snd_volume_multiplier=1.0, wake_uri=None, wake_word_name=[], wake_command=None, wake_command_rate=16000, wake_command_width=2, wake_command_channels=1, vad=False, vad_threshold=0.5, vad_trigger_level=1, vad_buffer_seconds=2, vad_wake_word_timeout=5.0, event_uri=None, startup_command=None, detect_command=None, detection_command=None, transcript_command=None, stt_start_command=None, stt_stop_command=None, synthesize_command=None, tts_start_command=None, tts_stop_command=None, streaming_start_command=None, streaming_stop_command=None, error_command=None, awake_wav='/usr/src/sounds/awake.wav', done_wav='/usr/src/sounds/done.wav', uri='tcp://0.0.0.0:10700', name='assist microphone', area=None, no_zeroconf=True, zeroconf_name=None, zeroconf_host=None, debug=True)
INFO:root:Ready
DEBUG:root:Connecting to mic service: ['arecord', '-r', '16000', '-c', '1', '-f', 'S16_LE', '-t', 'raw']
DEBUG:root:Connecting to snd service: ['aplay', '-r', '16000', '-c', '1', '-f', 'S16_LE', '-t', 'raw']
INFO:root:Connected to services
DEBUG:root:Connected to mic service
Recording raw data 'stdin' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
[16:39:50] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
DEBUG:root:Server set: 250287718150361
INFO:root:Streaming audio
DEBUG:root:Wake word detected
DEBUG:root:Connected to snd service
Playing raw data 'stdin' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
DEBUG:root:Event(type='transcript', data={'text': ' Wyłącz światło w pokoju.'}, payload=None)
DEBUG:root:Event(type='synthesize', data={'text': 'Zrobione', 'voice': {'name': 'pl_PL-gosia-medium'}}, payload=None)
It looks like it does not restart audio stream to openWakeWord. Any suggestions?
