Assist on Wear OS; Fail!
The documentation on this subject seems completely wrong and utterly confusing to me: Assist on Android
In bullet point #2 it says:
2. If it(*Assist*) does not (*appear automatically*), visit your watch companion app or the Wear OS app and select **Add tile** inside the **Tiles** area.
(The italic inside the parathesis was added by me)
First of all, there’s no such thing as a “watch companion App” on my Samsung Gear S3 and there’s no such App anywhere to be found in the Google Play Store. But the Wear OS App I have, installed and running on my Galaxy S23 phone, which is paired with my watch. But there’s no option inside the Wear OS App named Add tile and there’s no area named Tiles.
So what can I do?
Mmm, that watch runs under Tizen, not Wear OS, is it not?
How would I know? The watch came originally with a companion phone App named ‘GEAR’ which was later discontinued and replaced by an App named ‘WEAR’. This is now the only one available on Play Store and I’m using it to control my watch. Everything else works well using this WEAR App on my phone.
Well, does your app drawer looks like this and do you have access to the play store from the app?
If we are on the same page, the doc is about, from the Wear App (I guess “Cartes” is “Tiles”, and “Ajout de Carte” is “Add tile”)
Samsung Gear S3 - Wikipedia - The Samsung Gear S3 is a Tizen-based circular smartwatch developed by Samsung Electronics.
It’s not WearOS
Meaning what? Isn’t it compatible with Home Assistant Companion then?
no. The companion app is for WearOS, your watch runs Tizen
Ok, so that explains it then.
Perhaps such info should be added to the Docs? (I don’t know how to do that)
What, that the Samsung Gear S3 doesn’t run Wear OS?
No, that this feature/functionality only works with WearOS.
Perhaps that’s obvious, but it wasn’t for me as I wasn’t aware that my watch doesn’t run WeareOS despite the fact that the phone App I’m using with is called WEAR.
Confusing?
Call me picky but “Wear OS” is written 4 time in the first 4 sentences, plus there is a video and screenshots that, I suspect, don’t match your watch at all
I mean, I’m sorry you were confused, but you are supposed to know which OS your watch is running, surely before blaming the doc :wink:
There is this GitHub - jerrod-lankford/HAGearS3: Home Assistant user interface for the Samsung Gear S3/S2 (tizen os) - no idea if it still works, it’s quite old…
That is perfect! Thank you so much. Help at last :slightly_smiling_face:
No need for me to feel stupid just because I had never heard of Tizen before. But then, I have no idea what OS runs inside my coffee machine either… :no_mouth:
If it is any consolation: Samsung watch 4 and onwards are no longer running Tizen but are in fact running WEAR OS. They use the same app, which is probably why the name was changed to (Galaxy) Wear. It all adds to the confusion.
So if you ever decide to upgrade your watch to a newer version, you can use the official Wear OS companion app.
