Assistance for defining mqtt device using the new way described in 2022.6
In 2022.6 release notes, one of the breaking changes changed the way that mqtt devices were defined. It stated that the old way was deprecated, and described a new way to define the mqtt devices. I have made changes to my system using the new way for all the mqtt devices. They are not working. The “check configuration” show valid. I use VS Code to edit the files and it shows “duplicate keys” in the mqtt.yaml file.The devices show up in the entities page, but they are not “active”. For instance, I can click on a switch, but it does not do anything. No “on” or “off”.
 Below are parts of the 2 configuration files.
configuration.yaml ---
script: !include scripts.yaml
scene: !include scenes.yaml
#light: !include lights.yaml
binary_sensor: !include binary_sensors.yaml
#switch: !include switches.yaml
group: !include groups.yaml
sensor: !include sensors.yaml
mqtt: !include mqtt.yaml
mqtt.yaml ---
#***********SWITCHES ***********************
switch:
  - name: "middle door"
    command_topic: "cmnd/middle_door/POWER"
    state_topic: "stat/middle_door/status"
    qos: 1
switch:
  - name: "left door"
    command_topic: "cmnd/left_door/POWER"
    state_topic: "stat/left_door/status"
    qos: 1
switch:
  - name: "air compressor"
    command_topic: "cmnd/Air_Compressor/power1"
    state_topic: "stat/Air_Compressor/RESULT"
    qos: 1
switch:
  - name: "Motion Sensor_1_433"
    state_topic: "tele/RF_Bridge/RESULT"
    command_topic: "tele/RF_Bridge/RESULT"
    value_template: '{{value_json.RfReceived.Data}}'
    payload_on: "5A6AEC"
    payload_off: "5A6AECoff"
    qos: 1
#*****************LIGHTS*****************
light:
  - name: "Breakfast Dimmer"
    state_topic: "stat/Breakfast_Dimmer/POWER"
    command_topic: "cmnd/Breakfast_Dimmer/POWER"
    availability_topic: "tele/Breakfast_Dimmer/LWT"
    brightness_state_topic: "stat/Breakfast_Dimmer/RESULT"
    brightness_command_topic: "cmnd/Breakfast_Dimmer/Dimmer"
    brightness_scale: 100
    brightness_value_template: "{{ value_json.Dimmer }}"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    retain: false
light:
  - name: "Floor Dimmer"
    state_topic: "stat/Floor_Dimmer/POWER"
    command_topic: "cmnd/Floor_Dimmer/POWER"
    availability_topic: "tele/Floor_Dimmer/LWT"
    brightness_state_topic: "stat/Floor_Dimmer/RESULT"
    brightness_command_topic: "cmnd/Floor_Dimmer/Dimmer"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
light:
  - name: "Den Dimmer"
    state_topic: "stat/Den_Dimmer/POWER"
    command_topic: "cmnd/Den_Dimmer/POWER"
    availability_topic: "tele/Den_Dimmer/LWT"
    brightness_state_topic: "stat/Den_Dimmer/RESULT"
    brightness_command_topic: "cmnd/Den_Dimmer/Dimmer"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
light:
  - name: "Back Lights"
    state_topic: "stat/Back_Lights/POWER"
    command_topic: "cmnd/Back_Lights/POWER"
    availability_topic: "tele/Back_Lights/LWT"
    brightness_state_topic: "stat/Back_Lights/RESULT"
    brightness_command_topic: "cmnd/Back_Lights/Dimmer"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
Because your mqtt.yaml file shown above clearly contains duplicate keys. You used switch: four times and light: four times.
  • Put all four switch definitions under a single switch: key.
switch:
    qos: 1
  - name: "left door"
    qos: 1
    qos: 1
    qos: 1
  • Do the same for the lights; put all four light definitions under a single light: key.
Thanks, that did the trick!
Glad to hear it solved the problem.
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
For more information refer to guideline 21 in the FAQ.
