Assistance needed - Andersen Translator (Verilock Door Window Sensors)
I got a an Andersen Verilock Sensor for my sliding glass door, that reports lock status and open/close status. It communicates to a Translator device that connects through z-wave.
It supposedly works out of the box with wink and nexia. here is some documentation:
https://products.z-wavealliance.org/ProductManual/File?folder=&filename=Manuals/1173/18-HD75D1-1-EN.pdf
With that documentation, I got the translator connected over z-wave to homeassistant, and connected my door sensor to the translator.
Now I get this in the OZW_Log when I Open/Close/lock/unlcok the door:
Open:
2017-10-06 13:46:37.248 Detail, Node010,   Received: 0x01, 0x13, 0x00, 0x04, 0x00, 0x0a, 0x0d, 0x60, 0x0d, 0x07, 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x16, 0x00, 0x1e
2017-10-06 13:46:37.249 Detail,
2017-10-06 13:46:37.249 Error, Node010, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_ALARM endpoint 7
Close:
2017-10-06 13:47:16.218 Detail, Node010,   Received: 0x01, 0x13, 0x00, 0x04, 0x00, 0x0a, 0x0d, 0x60, 0x0d, 0x07, 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x17, 0x00, 0x1f
2017-10-06 13:47:16.218 Error, Node010, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_ALARM endpoint 7
Lock:
2017-10-06 13:47:48.205 Detail, Node010,   Received: 0x01, 0x13, 0x00, 0x04, 0x00, 0x0a, 0x0d, 0x60, 0x0d, 0x07, 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x01, 0x00, 0x09
2017-10-06 13:47:48.205 Error, Node010, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_ALARM endpoint 7
Unlock:
2017-10-06 13:48:07.207 Detail, Node010,   Received: 0x01, 0x13, 0x00, 0x04, 0x00, 0x0a, 0x0d, 0x60, 0x0d, 0x07, 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x02, 0x00, 0x0a
2017-10-06 13:48:07.207 Error, Node010, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_ALARM endpoint 7
I’m not sure where to go from here. looks like there is some community code for smartthings to make this work there…
https://community.smartthings.com/t/andersen-windows-connect-verilock-translator/85882/31
If anyone can help me out, I’d appreciate it. trying to not get in trouble for leaving the door unlocked!
Hey! So, I’m trying to get one of these working on my network as well. From what your logs tell me, it looks like you didn’t add it as a Secure Zwave device.
This is what I see in my logs
2017-10-08 12:26:48.954 Detail, Node036,   Received: 0x01, 0x13, 0x00, 0x04, 0x00, 0x24, 0x0d, 0x60, 0x0d, 0x02, 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x17, 0x00, 0x34
2017-10-08 12:26:48.954 Info, Node036, Received a MultiChannelEncap from node 36, endpoint 2 for Command Class COMMAND_CLASS_ALARM
2017-10-08 12:26:48.954 Info, Node036, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:23, status=255
2017-10-08 12:26:48.954 Detail, Node036, Refreshed Value: old value=0, new value=0, type=byte
2017-10-08 12:26:48.955 Detail, Node036, Changes to this value are not verified
2017-10-08 12:26:48.955 Detail, Node036, Refreshed Value: old value=0, new value=0, type=byte
2017-10-08 12:26:48.955 Detail, Node036, Notification: ValueChanged
2017-10-08 12:26:48.962 Detail, Node036, Notification: ValueChanged
That said, I’m still having issues with it. See here: Zwave Sensor State not changing
thanks for the tip. I removed the translator from the zwave network, and re-added it via a secure add. I’m still getting essentially the same type of messages in the log when I unlock/lock/open and close the door. I actually did this twice to make sure I hit the secure add after receiving the same type of response from the translator.
Here’s an unlock/lock sequence.
2017-10-08 21:34:21.595 Detail, Node012,   Received: 0x01, 0x13, 0x00, 0x04, 0x00, 0x0c, 0x0d, 0x60, 0x0d, 0x07, 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x02, 0x00, 0x0c
2017-10-08 21:34:21.595 Error, Node012, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_ALARM endpoint 7
2017-10-08 21:34:25.467 Detail, Node012,   Received: 0x01, 0x13, 0x00, 0x04, 0x00, 0x0c, 0x0d, 0x60, 0x0d, 0x07, 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x01, 0x00, 0x0f
2017-10-08 21:34:25.467 Error, Node012, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_ALARM endpoint 7
Under states, this is what the zwave device looks like:
zwave.nexia_unknown_type5a44_id414e
Ready
node_id: 12
node_name: Nexia Unknown: type=5a44, id=414e
manufacturer_name: Nexia
product_name: Unknown: type=5a44, id=414e
old_entity_id: zwave.nexia_unknown_type5a44_id414e_12
new_entity_id: zwave.nexia_unknown_type5a44_id414e
query_stage: Complete
is_awake: true
is_ready: true
is_failed: false
is_info_received: true
max_baud_rate: 40000
is_zwave_plus: true
capabilities: routing,beaming,listening
neighbors: 3,4
sentCnt: 9
sentFailed: 0
retries: 0
receivedCnt: 2
receivedDups: 0
receivedUnsolicited: 0
sentTS: 2017-10-08 21:32:12:969
receivedTS: 2017-10-08 21:31:52:925
lastRequestRTT: 76
averageRequestRTT: 102
lastResponseRTT: 217
averageResponseRTT: 214
friendly_name: Nexia Unknown: type=5a44, id=414e
I have the following sensors that don’t seem to change ever:
  • sensor.nexia_unknown_type5a44_id414e_alarm_level
  • sensor.nexia_unknown_type5a44_id414e_alarm_level_2
  • sensor.nexia_unknown_type5a44_id414e_alarm_type
  • sensor.nexia_unknown_type5a44_id414e_alarm_type_2
  • sensor.nexia_unknown_type5a44_id414e_emergency
  • sensor.nexia_unknown_type5a44_id414e_emergency_2
  • sensor.nexia_unknown_type5a44_id414e_sourcenodeid
  • sensor.nexia_unknown_type5a44_id414e_sourcenodeid_2
@chriskacerguis I factory reset the Translator, and re-paired it, I am now getting events in my log that match what you posted. But I’m not getting any working sensors either.
As as side note, I go my translator from a seller on ebay. Even though I bought 1, he sent me 3 of them (all used but better then paying full price). I have been trying to de-commission my smartthings hub, but pulled out one of the additional translators, and paired it with smartthings. Added the code I linked to above for the devices, and enrolled my door sensor. Smartthings is able to read the lock status and open/close status. Also the 2 translators are both able to see and read from the 1 sensor at the same time. so I can use this via the smartthings bridge, while at the same time try to troubleshoot the native ozw connection.
Any luck getting this to work correct? I’ve purchased one of these and they are a neat device if I can get it integrated to HA…
I gave up and got a sdr dongle and am able to use the rtl_433 program via a hassio addon to get the lock signals directly with out the translators.
Anyone ever get the Verilock translator working with HA? Or how did you get rtl_433 working with the Andersen window devices? Can I do that through MQTT?
I originally followed the how to in this thread, the verilock sensor show up as honeywell devices via rtl433: https://community.home-assistant.io/t/honeywell-5800-series-345mhz-door-and-window-sensor-integration-with-ha
After figuring out the device I ended up using this add-on to run the rtl433 to mqtt: https://github.com/james-fry/hassio-addons/tree/master/rtl4332mqtt
Awesome thanks for the share, I will look take a look.
