Assistance needed - Andersen Translator (Verilock Door Window Sensors)
I originally followed the how to in this thread, the verilock sensor show up as honeywell devices via rtl433: https://community.home-assistant.io/t/honeywell-5800-series-345mhz-door-and-window-sensor-integration-with-ha
After figuring out the device I ended up using this add-on to run the rtl433 to mqtt: https://github.com/james-fry/hassio-addons/tree/master/rtl4332mqtt
