Assistance with ESP YAML
Hi all,
I am attempting to update my ESP, used for opening/closing my garage door, but am receiving the following error:
INFO Reading configuration /config/esphome/garage-door.yaml…
ERROR Error while reading config: Invalid YAML syntax:
Duplicate key “name”
in “/config/esphome/garage-door.yaml”, line 86, column 5:
name: “Garage door closed”
NOTE: Previous declaration here:
in “/config/esphome/garage-door.yaml”, line 82, column 5:
name: “Garage door open”
I am assuming it is a formatting error but this code worked without problem previously:
binary_sensor:
  - platform: status
    name: "Garage Door ESP Status"
    name: "Garage door open"
    value_template: >-
      {{ is_state('switch.garage_door_open', 'on') }}
    name: "Garage door closed"
    value_template: >-
      {{ is_state('switch.garage_door_close', 'on') }}
Could anyone point me to what’s going wrong (I have attempted reformatting without success)
You have to add another - platform: template line for the second template sensor:
binary_sensor:
  - platform: status
    value_template: >-
    value_template: >-
Thanks, I am now getting the following error:
INFO Detected timezone ‘Europe/London’
Failed config
binary_sensor.template: [source /config/esphome/garage-door.yaml:81]
platform: template
name: Garage door open
[value_template] is an invalid option for [binary_sensor.template]. Please check the indentation.
value_template: {{ is_state(‘switch.garage_door_open’, ‘on’) }}
binary_sensor.template: [source /config/esphome/garage-door.yaml:86]
platform: template
name: Garage door closed
value_template: {{ is_state(‘switch.garage_door_close’, ‘on’) }}
That yaml is for HA, you need to use lambda in epshome:
Is the Lambda just used to turn analogue value into a binary sensor?
This doesn’t seem to work either.
Sorry, I wasn’t paying attention to the actual sensor configuration, but only the syntax.
Looking back at your original configuration: You appear to have 2 switches defined - are these switches defined on the ESP device? If so, the proper way would be to give each switch an ID, and then use those IDs in the template sensors’ lambdas.
So, for example, if you give one switch the ID garage_door_open, then the lambda would look something like:
    lambda: 'return id(garage_door_open).state;'
Yes the switches are defined within the ESP config, I am attempting to update within ESP home but my config is now showing the errors above (although it did previously work).
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "****"
  manual_ip:
    static_ip: '192.168.1.98'
    gateway: '192.168.1.1'
    subnet: '255.255.255.0'
  ap:
    ssid: "Garage-Door Fallback Hotspot"
    password: "****"
captive_portal:
logger:
  baud_rate: 0
api:
ota:
time:
  - platform: homeassistant
# Text sensors with general information.
text_sensor:
  # Expose ESPHome version as sensor.
  - platform: version
    name: Relay ESPHome Version
  # Expose WiFi information as sensors.
  - platform: wifi_info
    ip_address:
    bssid:
# Sensors with general information.
  # Uptime sensor.
  - platform: uptime
  # WiFi Signal sensor.
  - platform: wifi_signal
    name: Relay WiFi Signal
    update_interval: 60s
uart:
  baud_rate: 115200 # speed to STC15L101EW
  tx_pin: GPIO1
  rx_pin: GPIO3
binary_sensor:
  - platform: status
//  - platform: template
//    name: "Garage door open"
//    value_template: >-
//      {{ is_state('switch.garage_door_open', 'on') }}
//    name: "Garage door closed"
  lambda: |-
      {{ is_state('switch.garage_door_open', 'on') }} {
        // Garage Door is open.
        return true;
      } else {
        // Garage Door is closed.
        return false;
  lambda: |-
      {{ is_state('switch.garage_door_closed', 'on') }} {
        return true;
      } else {
        return false;
switch:
    turn_on_action:
      - uart.write: [0xA0, 0x01, 0x01, 0xA2]
    turn_off_action:
      - uart.write: [0xA0, 0x01, 0x00, 0xA1]
    internal: yes
    turn_on_action:
      - uart.write: [0xA0, 0x02, 0x01, 0xA3]
    turn_off_action:
      - uart.write: [0xA0, 0x02, 0x00, 0xA2]
    internal: yes
    name: "Garage Door Open"
    turn_on_action:
    - switch.turn_on: relay1
    - delay: 500ms
    - switch.turn_off: relay1
    - delay: 500ms
    - switch.turn_off: garage_door_open
    optimistic: true
    name: "Garage Door Close"
    turn_on_action:
    - switch.turn_on: relay2
    - delay: 500ms
    - switch.turn_off: relay2
    - delay: 500ms
    - switch.turn_off: garage_door_close
    optimistic: true
This is my full config
Well, those lambda statements underneath binary_sensor won’t work. But you should now be able to insert my previously suggested template binary sensor and that should work just fine.
And because the switches are actually template switches you could also toggle the template binary sensor from within the switches with the binary_sensor.template.publish action.
Appreciate the help, got it working by using your suggested template.
