Just wondering if someone here is using the Eufy Robovac integration by bmccluskey and is able to assist. I downloaded version 1.2.11 from HACS and successfully installed it without any issue. I’m using the G35+ model; it was successfully auto-discovered and added into HA. So far, all the controls work and automation is functioning as well.
However, in terms of data received from the vacuum, the only thing I can see on the Device menu with respect to sensor data is the battery status, which appears to be accurate. However, I’d like to also be able view sensor data from Accessory Services within the Eufy Clean app, including: 1) Sensors (when they need to be cleaned); 2) Dust Bag (when it needs to be re-emptied); 3) Filter (when it needs to be changed; 4) Side Brush (when it needs to be changed); 5) Rolling Brush; 6) Rear filter; and 7) Brush guard.
Even if I can’t reset these services from within HA and have to do it from Eufy Clean, it would be nice to at least be able to see the status of a few of these from within HA.
I’m also using the Xiaomi simple vacuum card to monitor the vacuum from the dashboard, but it shows certain sensor data has Unavailable.
I had a look at the vacuum.py and robovac.py files within Custom_Components for this configuration, and I can see references to “Consumables” for supported vacuum models, but this is as far as I’ve gotten.
I’m still quite new to HA and programming isn’t my forte as of yet (more of a general understanding of the logic but still need assistance with troubleshooting), so I’m wondering if someone also uses this integration and could advise.
