Assistance with parsing of JSON w/Jinja
HI all,
Seeking some assistance with parsing the following JSON in an MQTT sensor value template so that I can test against the section in bold only.
tele/sonoff/RF_Bridge/RESULT = {“RfRaw”:{“Data”:“AA B1 04 012C 028A 00B4 26AC 38090909290918181919090909090919191919181809 55”}}
So far I have this:
  - platform: mqtt
    icon: mdi:radar
    state_topic: "tele/sonoff/RF_Bridge/RESULT"
    value_template: >-
      {% if value_json.RfRaw.Data is equalto "XXXXXX"
        on
      {% else %}
        off
      {% endif %}
Does anyone have any examples where a string is parsed with a certain delimiter into an array?
Thanks!
Put this in the Template Editor and it will extract the second to last number (i.e. the long number) :
{% set x = "AA B1 04 012C 028A 00B4 26AC 38090909290918181919090909090919191919181809 55" %}
{% set y = x.split(" ") %}
{{ y[-2:-1] | join }}
Now to adapt it for your requirements, it’ll look something like this. I haven’t tried this so it may require further adjustments:
value_template: >-
  {% set y = value_json.RfRaw.Data.split(" ") %}
  {% set z = y[-2:-1] | join %}
  {% if z is equalto "XXXX" %}
  on
  {% else %}
  off
  {% endif %}
If you wish, you can combine it into one statement:
{% set z = value_json.RfRaw.Data.split(" ")[-2:-1] | join %}
Thanks so much @123!
that seems overkill. that’s going to get the 2nd to last item as a list, then combine it with nothing. If he wants the 2nd to last item as a string, then [-2] will suffice without the join.
Thanks! [-2] is so much neater!
I’m still a neophyte at slicing. My initial mistake was believing I needed the : in [ : ] so that led to [-2:-1] which doesn’t produce a string but a list element. I slapped on a join to convert it to a string. So my initial mistaken assumption led me to an unnecessarily long-winded solution!
The revised version is much cleaner:
{% set z = value_json.RfRaw.Data.split(" ")[-2] %}
Yeah, it only produces a list because it’s slicing instead of getitem. When you access an item in a list via a single value it returns the single value as the object that it is. It’s very useful.
