Assistant Typing Commands History
Was just in the Assistant command window testing some commands and each
time I have to retype the whole command, if I only need to make a small change.
Request would be command history like in terminal when if you press the up arrow
it would scroll up thru last 10-20 commands typed and enter them in the window
so you could then edit and make changes without having to re-type the whole command.
If anyone knows a way to currently do this just reply so everyone will know.
Thanks…
Mine works like that. Thought you were talking about something else.
So if you are on a dashboard in your browser and then click on the voice icon, then
type a command and press enter to execute the command, and then press up arrow
the previous command comes up?
I double checked it on my setup and get nothing.
I thought you were talking about the cli. You are right.
On a mobile device without hardware keyboard, the equivalent should be: scrolling up in the command history, long press on desired command, then choose “execute again” or “edit” from a context menu.
