Ever wanted to check your astrophotography session via your phone? Now you can.
AstroLive is a connector for the ASCOM Alpaca REST API designed to work with Home Assistant via MQTT. It supports the autodiscovery of Home Assistant for your observatory devices like your camera, telescope mount, focuser, filter wheel, and switch.
AstroLive is designed to run as a container to be deployed on a dedicated host or next to Home Assistant. It does not require any custom integration for Home Assistant since communication is sole via MQTT.
For each configured and connected component MQTT device configuration for sensors and if applicable a camera is created.
If the component is of the type camera the last captured FITS image is auto stretched, downsized, and published as a .jpg. This is the same for camera via file where AstroLive watches a directory for new FITS images.
Slewing the telescope using the equatorial coordinate system, moving the focuser and some more commands are possible directly from Home Assistant.
Find it here: AstroLive alongside the documentation on how to set it up.
This is AWESOME!!! I have used HA to control devices in my own home observatory for years. However, my integration has been limited to turning on/off the various devices using Shelly 1 12v Relays and a Digital Logger Web Switch. I never managed to get ASCOM integrated so that I could monitor/control ASCOM devices directly in HA. I started to play around with the Ground Station pluggin with MQTT in N.I.N.A, but this stilll did not give me current status of my ASCOM devices. It would appear from your dashboard screen shot that you may have “cracked the code” using AstroLive. I would love to learn more about this project. I have already checked out the AstoLive github and will try and install using docker as soon as I get a chance. Do you by chance have a link to your HA configuration?
Docker is not a must but simplifies the use because containerization creates a defined environment for the app. I describe the different variants on how to run AstroLive within the readme.
Same for the HA configuration. My nearly up-to-date configuration for the different devices is in the “Devices and Sensors” section of the readme or within the config directory of the repo. This should get you started, hopefully.
If you run into any problems just ask.
Clear skies!
Agreed, this is awesome. I made a few tweaks here and there to support my setup and the vagaries of N.I.N.A. and SGP, but apart from that it works very nicely. Happy to share the changes I made here or on Github…
Might I say this is very nice indeed. Would it be easy to integrate something like my NexDome Beaver ASCOM driver? I would like to have HA know the dome’s shutter is either open or closed so I can set the dehumidifier to turn on, etc. So much information…
This is absolutely possible. The single reason for me not having it implemented yet is that I don’t have a dome, sadly.
I’ll put it on my to-do list but will only be able to test against the ASCOM simulator, of course.
@stephen2615
I added Dome, Rotator, and Safety monitor. At least with the simulators, it seems to work. Maybe give it a try… Feedback would be appreciated.
