I have been using astroweather for monitoring cloud and seeing conditions, however i am not getting updates as the integration shows it is failing setup with the following error
If you try the url then my bitdefender says
msedge.exe attempted to establish a connection relying on an unmatching security certificate to www.7timer.info. We blocked the connection to keep your data safe since the used certificate was issued for a different web address than the targeted one.
that is the case, the certificate is a squarespace wildcard cert
we don’t need to use SSL though. there is no redirect from http → https, and it seems that the SSL part of this site goes to a squarespace under construction holding page
and the non SSL rewrites to http://167.99.8.254
shenanigans for sure, the IP 167.99.8.254 is a digital ocean site. I think what they should be doing is getting the likes of cloudflare infront of this and transferring the DNS away from squarespace.
