Just did a firmware upgrade (newest merlin) and i had to do a factory reset on my router.
Now my Hass.io gives me this error multiple times:
2018-03-14 16:40:56 ERROR (SyncWorker_14) [homeassistant.components.device_tracker.asuswrt] Connection refused.
b'@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@\r\r\n@
WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!
@\r\r\n@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@\r\r\n
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!\r\r\n
Someone could be eavesdropping on you right now (man-in-the-middle attack)!\r\r\n
It is also possible that a host key has just been changed.\r\r\n
The fingerprint for the ECDSA key sent by the remote host is\r\n
SHA256:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.\r\r\n
Please contact your system administrator.\r\r\n
Add correct host key in /root/.ssh/known_hosts to get rid of this message.\r\r\n
Offending ECDSA key in /root/.ssh/known_hosts:1\r\r\n
ECDSA host key for 192.168.111.1 has changed and you have requested strict checking.\r\r\n
Host key verification failed.\r\r\n'
Anyone know how to reset this host key / known_hosts?
The error is telling you that the host key recorded in your hassbian machine doesn’t match the one presented by the router. Sounds like the router has a new host key.
The error message is telling you that the key is in the file /root/.ssh/known_hosts at line 1
Here’s how to reset:
Open this file in your favorite editor as root or sudo and delete line 1. Save the file and then try to connect again.
I found the file in /home/homeassistant/.ssh/ with filename known_hosts. I deleted the first line in nano using Ctrl+K, saved and did and reboot, and all fine now.
Rather than editing the file, you can also remove the old host using ssh-keygen, which should find your default .ssh files. It also backs up your known_hosts before changing it.
