Asus Tinker Board: Error setting up platform bluetooth_tracker
I just added the bluetooth tracker to my configuration but its not working.
Configuration:
  • platform: bluetooth_tracker
    interval_seconds: 15
    consider_home: 150
    track_new_devices: yes
Error:
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/init.py”, line 183, in async_setup_platform
disc_info)
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py”, line 73, in setup_scanner
for dev in discover_devices():
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/bluetooth_tracker.py”, line 51, in discover_devices
lookup_class=False)
File “/usr/local/lib/python3.6/site-packages/bluetooth/bluez.py”, line 26, in discover_devices
device_id = _bt.hci_get_route()
OSError: [Errno 19] No such device
I also added the BLE Tracker, but it seems that the device does not support it (No BLE adapter found).
  • platform: bluetooth_le_tracker
I am using the Asus Tinker Board S. Maybe I have to install / configure something?
Did you ever figure out BL/BLE on the tinker board?
Not yet, I tried to setup bluetooth but without success.
I suppose the bluetooth is not activated on tinker, so I dont think its a problem in HA.
Any help would be nice!
Hi Taddeuz,
I got the same problem. I reinstalled everything but nothing works. I hope some one can help us soon!
Best Mark
Hope so, I already had a look at the asus tinker forum, but nothing found.
I plugged in a bluetooth USB dongle and BL is working now, I will test BLE (Tile and Mi Flora) later. Looks like the image or something isn’t right…
I just ordered a Bluetooth dongle. Hope it works.
I just tested a dongle with Bluetooth version 4.0. Bluetooth is working but BLE isn’t…
Ordered a Bluetooth dongle from asus and its working fine.
Also the BLE? What type do you use?
I am using the Bluetooth Tracker. Seems to be working fine, but tested it only for one device. The device is listed in known_devices.yaml
device_tracker:
