Thanks for looking Mukund, strange that the ASUS DSL-AC56U Modem doesnt run dnsmasq too
Hi Craig
I’m assuming you are running stock firmware.
Have you looked at https://github.com/RMerl/asuswrt-merlin?? Just did a quick search and Search results are positive for dnsmasq.
Mukund
Hi Mukund
Yeah Im running the latest and greatest ASUS firmware ( Version 1.1.2.2_36 released 28/3/2017) direct from ASUS (https://www.asus.com/au/Networking/DSL-AC56U/HelpDesk_Download/)
I read up on Merlin, and there it sounds very likely that Merlin hasn’t been designed for DSL type ASUS modem’s and wont support the DSL functionality, and potentially will brick the modem.
I’m just looking into forking the Home Assistant git repo and looking at tweaking the ASUSWRT.py component library to handle udhcpd leases. I’m just reading up on the dev notes now.
I’ll keep you posted
Craig
Sounds like a plan. Let me know how you go.
Hi Mukund
I had a look at the python code and I was having some issues re-working the regex to handle to the new formatting of the dhcpd_lease file and time ran out. So i ended up taking the ASUS DSL-AC56U back to the shop and paid the difference to get the AC68U model the same as you.
And yep the dnsmasq.lease is right where it should be, and happy days my device tracking is working as it should be now.
Thanks for your help looking up that dnsmasq was present on the AC68U model
Craig
Maybe using the web interface given the example here will be easier?
Hi Craig
Good that its working for you. I think the 68U is better anyway regardless of the HA compatibility.
Mukund
hey guys hope someone can help me i use asus wrt for device tracking it worcks fine
but every day around midday all my devices change to away even though they are at home
i have RT-AC68P
this is my config
device_tracker:
- platform: asuswrt
host: my ip address
username: mysecretusername
password: mysecretpassword
protocol: telnet
interval_seconds: 10
consider_home: 180
track_new_devices: yes
device_tracker:
- platform: asuswrt
host: my ip address
protocol: telnet
consider_home: 180
Hi Kem
This is probably due to the ip leases your router assigns expiring. I dare so you have a 24 hr lease period setting on your router and you would have done a router reboot sometime in the recent past around midday which reset all the existing device ip renewals.
You should be able to increase the expiry period for assigned ip addresses on the router. But at some stage they will expire. But the device should literally flick offline for a few seconds and then be back on the network again with the same ip but with a fresh renewal period.
Craig
thanks for the replay can you point me on where on my router settings should i look and ones again thanks
Kem
The IP lease setting can be found in LAN - DHCP Server Tab, there will be a lease time variable you can set. Mine is currently set at 86,400 seconds (24 hrs), which is the default.
Craig
i got thank you so much for taking the time help me
I’m trying to use AsusWRT on my AC68U
I tried both telnet and ssh by username and password. Same return as SSH enable?
on the router log. it says login attempt from nonexsistent user.
I can login from my raspberry pi by ssh [email protected] it works.
Any suggestion?
device_tracker:
platform: asuswrt
host: 192.168.*****
username: admin
password: *******
protocal: telnet
mode: router
protocal: telnet
interval_seconds: 61
consider_home: 180
this my be a dumb question but it happen to me have you enable telnet on your router ??
Hi, Kem
thanks for your reply.
Just double checked it is enabled.
ok it happen to me i was about to give up wen i find out im sorry i can’t be more helpful im new to all this
Hi There
Yes you will need to enable Telnet on the router, its found in the “Administration” menu as a Enable Telnet tickbox.
Also your configuration file information had some issues with it such as :
platform: asuswrt
host: 192.168.*****
username: ‘admin’ * Needs inverted commas around text
password: ‘*******’ * Needs inverted commas around text
protocol: telnet * Protocol misspelt, and only need it once
mode: router
consider_home: 180
yes my configuration is working everthing is good thanks
