ASUSRouter Integration - requires second reboot
I have been using the ASUSRouter integration for about 2 years. Over the past few months, it has begun an odd behavior where almost every time I reboot Home Assistant (e.g. updates, etc.) the ASUSRouter integration fails to reload (usually just the main router, not the remote mesh node). Then, if / when, I reboot HA again, it comes quickly back on-line as is should.
Has anyone else experienced this? Any suggestions on how to remedy it?
There might be some code you could run to restart it some time delay after HA startup, but there really sounds like the integration has a problem.
Perhaps an issue is in order with lots of evidence and log evidence.
The assumption will be that you are running a supported version of HA though.
