I would like to know how I could use the options: "interval_seconds: " and “consider_home:” , after asuswrt started to be a component .
Error message below:
Failed config
asuswrt:
- Invalid config for [asuswrt]: [interval_seconds] is an invalid option for [asuswrt]. Check: asuswrt->asuswrt->interval_seconds. (See /config/configuration.yaml, line 87). Please check the docs at https://home-assistant.io/components/asuswrt/
- asuswrt: [source /config/configuration.yaml:87]
host: 192.168.1.1
interval_seconds: 5
port: XXX
ssh_key: /config/ssh/xxxxxx
username: XXXX
Thank you.
