Asuswrt device tracker is broken - please release a fix
you need some more feedback from ssh. -v goves you verbose output, and every time you add another v you get more feedback. So try
ssh -vvv [then the rest of your normal ssh command]
nice! didn’t know that, thanks.
result:
OpenSSH_7.7p1, LibreSSL 2.7.3
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 48: Applying options for *
debug2: resolve_canonicalize: hostname 192.168.1.1 is address
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to 192.168.1.1 [192.168.1.1] port 22.
debug1: connect to address 192.168.1.1 port 22: Connection refused
ssh: connect to host 192.168.1.1 port 22: Connection refused
was thinking maybe the firewall causes this, but disabling that gives the same result.
I guess the other test is
nmap -p 22 IPADDR
and see if the port is even open (or run ssh with another v)
I tried adding another v but that didn’t change the output.
nmap sint recognized:
nmap -p 22 192.168.1.1
-bash: nmap: command not found
just to be 100% positive about the ip address:
https://192.168.1.1:8443 logs me in to the webinterface .
I had capitals in my username, thought that might trouble the setup, so took these out. Still no luck…
btw, I use a RT-AC3200
—UPDATE—
I am in! after changing all obvious and less obvious settings in the router, I changed login name to lowercase only and logged out to login with the new username. Of course I was locked out… simply no way to login anymore, mac or app.
decided the last and final option before resetting factory settings, and hardware rebooted.
et voilà: the ssh into the router went smooth as silk:
debug2: we sent a password packet, wait for reply
debug3: receive packet: type 52
debug1: Authentication succeeded (password).
Authenticated to 192.168.1.1 ([192.168.1.1]:22).
now hoping HA can log in too…#fingerscrossed
–UPDATE2–
bingo!
2018-12-12 10:01:00 INFO (MainThread) [homeassistant.setup] Setup of domain asuswrt took 13.4 seconds.
13
thanks for all your help!!
