Not sure if anyone has had a similar issue, but all of a sudden the device tracker which I use via AsusWRT, loses connection after around 5 hours. I get a host timeout and then my device tracking abilities is gone. Everything else on the router, however, is fine, but I need to restart Home Assistant to get the device tracking working again.
I have tried to do a factory reset on the router (Asus AC-RT66) but that didn’t help.
Has anyone else experienced something similar?
Example:
Logger: homeassistant.components.device_tracker
Source: components/device_tracker/legacy.py:320
Integration: Device tracker ([documentation](https://www.home-assistant.io/integrations/device_tracker), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+device_tracker%22))
First occurred: January 9, 2021, 5:03:58 PM (4276 occurrences)
Last logged: 3:05:54 PM
Updating device list from legacy took longer than the scheduled scan interval 0:00:12
Logger: aioasuswrt.connection
Source: /usr/local/lib/python3.8/site-packages/aioasuswrt/connection.py:120
First occurred: January 9, 2021, 5:03:44 PM (5869 occurrences)
Last logged: 3:08:15 PM
Host timeout.
