I would like to setup the ASUSWRT Tracker. I have a RT-AC87U in AP mode, it has 2.4Ghz and 5Ghz.
The problem is, the tracker only tracks devices who are connected to the 2.4 band.
Is there a solution?
I’m using the Asus RT-AC3200 and it tracks both my 5GHz bands fine. Perhaps try updating firmware (I’m using the latest Merlin release)?
Hi, I’m facing the same issue. I’m not using Merlin. Have you found a way to fix it?
