please consider adding optional creation of the presence detection sensors. As it stands, they are automatically created by default upon setup of the integration, and, as I have experienced, interfere with already existing presence detection sensors, or network scanners.
I understand, and have done so, we can disable these sensors, but even then, they use an entity_id.
Adding an option in the config flow of the integration to create sensors for Presence detection and Sensor, as described on https://www.home-assistant.io/integrations/asuswrt/ could prevent this from happening.
If at all possible, the media_players would be a possible third category. In my use case:
I do like to see the sensors for speed and clients connected, and the media_players with their command options. Don’t need the device_trackers.
thanks for considering.
