I recently built a simple RF receiver and sender coupled to an ESP32, which I tried to flash, but does not compile on ESPhome 1.13.6.
Yesterday I tried flashing (and compiling) it on HA 0.94.0, but it gave async errors. After seeing github issue I thought the easiest fix was to update HA to 0.97.1.
Now at 0.97.1, it still will not compile. The total log of ESPhome is given below. What should I do?
INFO Reading configuration...
INFO Generating C++ source...
INFO Compiling app...
INFO Running: platformio run -d /config/esphome/esp32_1
Processing esp32_1 (platform: [email protected]; framework: arduino; board: esp32doit-devkit-v1)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32doit-devkit-v1.html
PLATFORM: Espressif 32 > DOIT ESP32 DEVKIT V1
HARDWARE: ESP32 240MHz 320KB RAM (4MB Flash)
DEBUG: CURRENT(esp-prog) EXTERNAL(esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF MODES: FINDER(chain) COMPATIBILITY(soft)
Collected 30 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <ArduinoJson-esphomelib> 5.13.3
|-- <AsyncMqttClient> 0.8.2
| |-- <AsyncTCP> 1.1.0
|-- <ESP Async WebServer> 1.1.1
| |-- <AsyncTCP> 1.1.0
| |-- <WiFi> 1.0
| |-- <FS> 1.0
|-- <ESPmDNS> 1.0
| |-- <WiFi> 1.0
|-- <FS> 1.0
|-- <Preferences> 1.0
|-- <Update> 1.0
|-- <WiFi> 1.0
Compiling /data/esp32_1/.pioenvs/esp32_1/lib7e1/AsyncTCP_ID1826/AsyncTCP.cpp.o
Archiving /data/esp32_1/.pioenvs/esp32_1/libc92/libAsyncMqttClient_ID346.a
Compiling /data/esp32_1/.pioenvs/esp32_1/lib090/WiFi/ETH.cpp.o
Compiling /data/esp32_1/.pioenvs/esp32_1/lib090/WiFi/WiFi.cpp.o
Compiling /data/esp32_1/.pioenvs/esp32_1/lib090/WiFi/WiFiAP.cpp.o
/data/esp32_1/.piolibdeps/AsyncTCP_ID1826/src/AsyncTCP.cpp: In function 'bool _start_async_task()':
/data/esp32_1/.piolibdeps/AsyncTCP_ID1826/src/AsyncTCP.cpp:205:141: error: 'xTaskCreateUniversal' was not declared in this scope
xTaskCreateUniversal(_async_service_task, "async_tcp", 8192 * 2, NULL, 3, &_async_service_task_handle, CONFIG_ASYNC_TCP_RUNNING_CORE);
* [/data/esp32_1/.pioenvs/esp32_1/lib7e1/AsyncTCP_ID1826/AsyncTCP.cpp.o] Error 1
========================== [ERROR] Took 35.03 seconds ==========================
My current ESPhome configuration for the ESP32 is below.
(Sorry for the necro, but posting for someone looking for the solution.) In the end it came down to a shortage of RAM on my RPi. Shutting down some containers allowed it to compile and upload.
