Hello!
I’m having a problem with HA that I’m having big trouble finding a solution for. Errors from the log are below.
What I know:
- The error is most likely related to rflink which is connected via a tcp socket. After the error occurs all sensors and lights connected via rflink stop working until I restart ha.
- this error has only started to happen since I’ve updated from an older version prior the new versioning scheme (I believe it was 0.117). Before updating home-assistant rflink never stopped working or made problems.
- The issue occurs when a switch activates a scene
- I am unable to trigger the issue on purpose, it occurs at a seemingly random point in time.
- a restart of home assistant fixes the issue.
- I do have an occasion warning in the logs, but so far this has never been a problem. Posting it here to draw a complete picture:
WARNING (MainThread) [homeassistant.components.rflink] disconnected from Rflink, reconnecting
Any help pinning this down would be greatly appreciated!
Automation of the switch:
- id: 'xxx'
alias: namedautomation
description: ''
- device_id: xxx
discovery_id: 0x14b457fffe915cb3 click_on
domain: mqtt
platform: device
subtype: 'on'
type: click
condition: []
- scene: scene.nameofthescene
mode: single
Scene:
- id: xxx
entities:
light.light1:
assumed_state: true
effect_list:
- colorloop
- night
- white
friendly_name: Light 1
state: 'on'
supported_features: 61
light.light2:
friendly_name: Light 2
state: 'on'
supported_features: 0
light.light3:
friendly_name: Light 3
state: 'on'
light.light4:
brightness: 255
friendly_name: Light 4
state: 'on'
supported_features: 1
light.light5:
friendly_name: Light 5
state: 'on'
light.light6:
assumed_state: true
effect_list:
- colorloop
- night
- white
friendly_name: Light 6
state: 'on'
icon: mdi:lightbulb-on-outline
For the sake of completeness let me add that theres also a sepparate Scene and according automation for turning them all off.
Error Log:
2021-02-13 19:46:27 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Error when calling service during mobile_app webhook (device name: nameofdevice):
2021-02-13 19:46:27 ERROR (MainThread) [homeassistant.components.webhook] Error processing webhook 1cde7c3402980bac05f18819885a6eb46b1ec6be6179b4906efe376e47106e41
File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 221, in webhook_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1455, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1490, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 595, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 664, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 632, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/homeassistant/scene.py", line 311, in async_activate
await async_reproduce_state(
File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 106, in async_reproduce_state
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/helpers/state.py", line 100, in worker
await platform.async_reproduce_states( # type: ignore
File "/usr/src/homeassistant/homeassistant/components/light/reproduce_state.py", line 139, in async_reproduce_states
File "/usr/src/homeassistant/homeassistant/components/light/reproduce_state.py", line 126, in _async_reproduce_state
task.result()
await coro
await result
File "/usr/src/homeassistant/homeassistant/components/rflink/__init__.py", line 565, in async_turn_off
await self._async_handle_command("turn_off")
File "/usr/src/homeassistant/homeassistant/components/rflink/__init__.py", line 498, in _async_handle_command
await self._async_send_command(cmd, self._signal_repetitions)
File "/usr/src/homeassistant/homeassistant/components/rflink/__init__.py", line 524, in _async_send_command
await self._protocol.send_command_ack(self._device_id, cmd)
File "/usr/local/lib/python3.8/site-packages/rflink/protocol.py", line 227, in send_command_ack
yield from asyncio.wait_for(
File "/usr/local/lib/python3.8/asyncio/tasks.py", line 501, in wait_for
raise exceptions.TimeoutError()
asyncio.exceptions.TimeoutError
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 96, in async_handle_webhook
response = await webhook["handler"](hass, webhook_id, request)
File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 205, in handle_webhook
return await asyncio.shield(
File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 140, in validate_and_run
return await func(hass, config_entry, data)
File "/usr/src/homeassistant/homeassistant/components/mobile_app/webhook.py", line 235, in webhook_call_service
raise HTTPBadRequest() from ex
aiohttp.web_exceptions.HTTPBadRequest: Bad Request
2021-02-13 19:46:32 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Error when calling service during mobile_app webhook (device name: nameofdevice):
2021-02-13 19:46:32 ERROR (MainThread) [homeassistant.components.webhook] Error processing webhook 1cde7c3402980bac05f18819885a6eb46b1ec6be6179b4906efe376e47106e41
task.result()
await coro
await result
task.result()
await coro
await result
2021-02-13 19:46:37 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Error when calling service during mobile_app webhook (device name: nameofdevice):
2021-02-13 19:46:37 ERROR (MainThread) [homeassistant.components.webhook] Error processing webhook 1cde7c3402980bac05f18819885a6eb46b1ec6be6179b4906efe376e47106e41
task.result()
await coro
await result
task.result()
await coro
await result
2021-02-13 19:46:42 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall scene.turn_on (c:9af92775d319d06e7da466f9c3084476): entity_id=['scene.feuer_gemutlich']>
File "/usr/src/homeassistant/homeassistant/core.py", line 1471, in catch_exceptions
await coro_or_task
await coro
await result
task.result()
await coro
await result
2021-02-13 19:46:47 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall scene.turn_on (c:78dc5d4133a0e586ffb3bd0ae48fc1c0): entity_id=['scene.feuer_gemutlich']>
await coro_or_task
await coro
await result
task.result()
await coro
await result
2021-02-13 19:47:14 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140458506712112]
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 136, in handle_call_service
task.result()
await coro
await result
task.result()
await coro
await result
Thank you!
