I purchased the Home Assistant green after reading that it was ready to use right out of the box. It is up and running, but neither the Apple app, homeassistant.local:8123, or homeassistant:8123 can connect to the device. The app gives the error 1004 when I try to connect manually since it doesn’t connect automatically. My browser on the other hand just says it cannot reach the address. I have also plugged the device into my TV via HDMI to find its IP address, but connecting to it through the browser that way also does not work.
I am on my iPhone, and I turned off private relay and the private Wi-Fi address settings, as someone here suggested, but that also has not helped. I have also tried using another browser, but that also does not work.
I am at a loss! Everybody on the online forums talks about their more complicated set ups, but this is just a Home Assistant green and should be easy to use. Can someone help me?
