The name tag on the top is for attribution. I am not the original author of this. Petro is… petro - Original post
Templates will update once a minute if you have the following functions in the template:
now()
utcnow()
today_at()
relative_time()
Templates will update when a state changes if you use
I have one thing to add, and someone please correct me if I’m wrong, but as far as I can tell a time-based trigger in a template will work down to the second, as in:
Yes, but the post is not about template entities. It’s about the template itself, as in the jinja.
The template itself (without a trigger) will cause a template entity or a frontend field using the template to update based on the information in the guide. Or if you use the template for history stats start and end, it will cause those to render based on the information above.
