Hi, i am new on homeassistant. I use HA 0.114.0 I also use integration Atagone. But after restart router Atagone got a new IP address. Where in HA can I set the Atagone IP address to the new value?
Ik had the same problem.
You can delete and add the integration again. I think, if you did not rename entities, it should work without issues.
What I did to prevent an IP address change:
In my router I can assign an IP address to an MAC address, so DHCP always assigns the same IP address.
Hope this helps.
