Yep, that’s why I suggested within Home Assistant to do the following:
Settings->Devices & Services->ESPHome->Add Device
Then you should be able to put the IP address or hostname of the device and ESPHome should then be able to add it to the dashboard. If that doesn’t work then something weird is happening and I’d recommend you chat with the ESPHome folks on Discord.
A question regarding Occupancy… Most of the time this works, but the odd time in my lounge the pir sensor would detect motion, the mmware would not detect motion (as its beyond the range i have set) - but this would not trigger the Occupancy to Detected.
I would have thought that either the pir or the mmWave would trigger Occupancy and the mmWave would keep it on until someone left the room?
Since today’s ESPHome 2024.5.1 update, i’ve started to get the following error. Does anyone know how to fix this? I’ve read something about a minimal firmware to flash to enable OTA again – is this the right path?
I’m seeing exactly the same - looks like the size of the compiled file is maybe bigger than before - never had an issue before the latest updates
To be honest, I can’t see any reason to continually update ESPHome and take the considerable time to update all devices. Seems like a pretty poor system when there are no useful updates to these devices.
This one from @tarontop catched my eye.
EDIT: i’ve tried it and i couldn’t increase the flash size to 2MB at all.
Only solution which worked was to downgrade via HA partial backup to ESPHome 2024.4.2,
then install the 2024.4.2 to all Athom’s, and finally to upgrade ESPHome back to 2024.5.2 and upgrade all Athom’s to the latest version. – very cumbersome process –
Yes but a) you have to look through the update docs and try to work out how the device is affected and b) I don’t think there’s any way to skip the update so it will continually show and nag you.
Not really. If it isn’t broken, just leave it. It’s very rare that ESPhome updates include ‘breaking changes’.
Just hit the ‘skip update’ button and it won’t nag you until the next monthly update, or leave out the ‘firmware version’ section of code so HA doesn’t respond at all. My Athoms are like this, they show an update as being available in the ESPhome dashboard but not in the HA updates section.
FYI @Hell255 I had the same issue as you. I decided to just disable the update entity for the Athom presence sensors. If some breaking change is released later I will do the work to connect a USB cable and update locally, then maybe OTA updates would work afterward. I followed the steps at the below link to resolve it for my Athom sensors. Now I won’t see the update available notifications for them…
@sparkydave interesting that the update worked for you without issues. I had been updating my Athoms diligently with every ESPHome update. Latest I was able to update was ESPHome version 2024.5.0. Now it won’t work over OTA, with the size error Hell255 mentioned. You must be lucky; buy a lottery ticket!
Still, if the latest OTA really doesn’t work for you, then do a 2-step OTA procedure:
First, install a minimal version with OTA.
Second, install the full version with OTA. Don’t forget to change your friendly_name, name and key.
Note: sometimes i had to retry the update several times until it went through.
Thanks for sharing this, but even with the base config and trying it a BUNCH of times including resetting the device - I didn’t have any luck.
I think I’m going to have to factory reset my two units, adopt them, and then update their configs.
I have 2 of these. One in my living room and one in my basement media area. Main purpose is to turn off the lights/tv when no one is there and they are left on. I am overall very happy with the devices. using blakadder’s config.
I have several different esp based presence sensors (screek, athom, apollo, seeedstudio kit). The best in my opinion on accuracy/true positives/false positives are the screeks. I haven’t played much with the apollo one yet. The athoms are good enough and reliable enough that I put them to use right away with minimal tweaking to get the result I was looking for. I would recommend also looking into the screek products (I am using two 2A’s and one 1U). They don’t however have a PIR if that is something you specifically are wanting.
Thanks for sharing your experience! I was considering the screek devices for a time, then decided to just build the rest of my presence sensors using ESP32 boards and sensors from Ali Express.
The “homemade” presence sensors work well now, but required a LOT more tuning that the Athom sensor. Athom sensors work really well and require minimal setup. Glad to hear the screek are pretty good too. I believe the Apollo is highly rated & you’ll find that works very well too.
I’m thinking a nice upgrade to these sensors would be a temperature sensor. Has anyone else tried doing this? It looks like there’s a few free I/O’s which could possibly make this work with a DS18B20 or something.
