Athom Tasmota Curtain Module KM01
Original product link
This page leads to a confusion, as GPIO for the Switch2 and LedLinki are swapped:
GPIOs:
GPIO# Component
GPIO0 None
GPIO1 None
GPIO2 None
GPIO3 LedLinki GPIO13 LedLinki
GPIO4 Switch1
GPIO5 Button1
GPIO9 None
GPIO10 None
GPIO12 Relay1
GPIO13 Switch2 GPIO3 Switch2
GPIO14 Relay2
GPIO15 None
GPIO16 None
GPIO17 None
FLAG None
In addition, wiring graphs suggest that switches must be connected to S1/S2 plus L, that didn’t work for me untill I used N.
Next follows my esphome yaml file for a shutter:
substitutions:
  devicename: b28-shutter-5
  u_devicename: Shutter 5
  friendly_name: $u_devicename
esphome:
  # name_add_mac_suffix: true
  project:
    version: "0.1"
esp8266:
  board: esp8285
wifi:
  # use_address: 192.168.88.74
  networks:
  - ssid: !secret wifi_ssid
  ap:
    ssid: "$u_devicename Hotspot"
captive_portal:
api:
ota:
web_server:
  port: 80
logger:
  baud_rate: 0
  - platform: uptime
    disabled_by_default: true
  - platform: wifi_signal
    name: "WiFi Signal $u_devicename"
    update_interval: 60s
status_led:
  pin:
    number: GPIO13
    inverted: yes
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: GPIO5
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      then:
        # - cover.toggle: shutter_5
        - if:
            condition:
              lambda: "return id(shutter_5).position == COVER_OPEN;"
            then:
              - cover.close: shutter_5
            else:
              - cover.open: shutter_5
  - platform: gpio
    pin:
      number: GPIO4
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      - logger.log: "$u_devicename switch open"
  - platform: gpio
    pin:
      number: GPIO3
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      - logger.log: "$u_devicename switch close"
button:
  - platform: factory_reset
    name: Restart with Factory Default Settings
text_sensor:
  - platform: wifi_info
    ip_address:
      name: $u_devicename IP Address
    ssid:
switch:
  - platform: gpio
    pin: GPIO12
    interlock: &interlock [relay_open, relay_close]
  - platform: gpio
    pin: GPIO14
    interlock: *interlock
cover:
  # - platform: time_based
    device_class: shutter
    open_action:
      - switch.turn_on: relay_open
      - switch.turn_off: relay_close
    # open_duration: 60s
    close_action:
      - switch.turn_on: relay_close
      - switch.turn_off: relay_open
    # close_duration: 60s
    stop_action:
    optimistic: true
Why don’t you talk to Athom? It is as you advise here
I already did! I sent them this link…
Please refer to the configuration of tasmota. There is no problem with the GPIO of tasmota and it has been verified.
https://templates.blakadder.com/athom_KM01-TAS.html
