Atlas Scientific (EZO-PMP) - Peristaltic Pumps
EZO-PMP Blueprint Collection
These blueprints are intended to control Atlas Scientific (EZO-PMP) peristaltic pumps in I2C mode via Home Assistant frontend.
Water Change
Control 2 EZO pumps simultaneously to remove waste water while adding clean water.
Theses are intended for aquarium water changes or dosing liquids for the AquaPi but can be used for any EZO pumps.
NOTE: Using Dose Volume for Time can fail sometimes. In using the pump to dose 5 gallons over 8 hours, sometimes the pump would stop working and it would needed to be tapped or jostled to get it started again.
Try only using the Quick Water Change blueprints.
Aquarium - Water Change
Turn on two EZO Pumps simultaneously to remove waste water and add clean water, in gallons.
Aquarium - Quick Water Change
Turn on two AquaPi EZO Pumps simultaneously to remove waste water and add clean water, in gallons.
Aquarium - Daily Water Change
Turn on two EZO Pumps simultaneously to remove waste water and add clean water daily, in gallons, per month.
Aquarium - Daily Quick Water Change
Turn on two EZO Pumps to simultaneously remove waste water and add clean water daily, in gallons, per month.
Dosing
Aquarium - Dosing
Control an EZO pump to dose a specific amount of liquid.
Created for AquaPi
